Valve check/adjust thur/fri at my place. 4v ST4s.
Started by sdlrodeo, March 29, 2009, 07:09:56 PM
Cher
Quote from: sdlrodeo on April 02, 2009, 07:33:20 PM
Ok, I've decided I'm going to do the valve check starting Friday morn. I'm also installing rearsets from an 888 and clipons as well. This could render the ST4s into an ST4r and make it not so comfy for the long hauls. We'll see.
So, if you're bored and feel like dropping by, call first at 972-567-6375 (I may on parts run).
Steve
Hey there Steve, how'd the mad wrenching go?  Wish I could have made it over to see the action ('action' in this case being, just to be clear, the singular endeavour of affecting mechanical improvement to a static, mechanical device, i.e., a gasoline powered internal combustion, twin-cylinder engine - with an included angle of 90 degrees - manufactured from alloy composite material; functioning with four strokes per combustion cycle of 916cubic centimeters in volumetric displacement, that employs desmodromic intake and exhaust valves actuated directly by lobes on the twin overhead camshafts and other completely inexplicable design "features" unique to Italian motorcycle motors, Ducatis in particular)   [evil]
;D  Seriously, hope it went well.
Lisa
sdlrodeo
#16
ahem, 996 thank you very much.
(said in proud father tone)
And it IS GOING well. By the time I got all the body work, tank (gas tastes like crap but it's not so bad the second time the syphon stops working, and even less yucky the third), radiator (fluid is rather slippery), Airbox, Throttle bodies, and valve covers, i had enogh time to measure all shims and take off the vert belt and adjust the vert exhaust shims. I just have to adjust the rest of them now. Good news is that the rockers on both sides of the vert head looked good without any flaky chrome! Hope the rest look as good. I'm hoping to have it back together thursday or friday at the latest.
That tech session with Stuart sure did help out a lot!
the saga continues...
Steve
Wrist is to throttle as finger is to trigger.
Ronr
Way to go Steve! Glad to hear it's going well.
Duc L'Smart
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
Samsonite
Suzuki DS 80   Suzuki SP 125   Suzuki GSXR 1000   Ducati M600   Ducati SC 1000   Ducati S4R 1000   Ducati PS1000LE   Ducati 1098S   Yamaha YZFR 1000   Yamaha YZFR 600   Ducati Sport 900   Yamaha YSR 50   Triumph Daytona 600   2006 Suzuki GSX-R 600
RED
Quote from: AeroGeek on April 04, 2009, 06:54:15 AM
That explains the carpal tunnel
Cute,  [laugh]  [clap]
Quote from: Samsonite on April 04, 2009, 06:33:13 AM
No worries.... [roll]  [laugh]
Quote from: sdlrodeo on April 04, 2009, 06:30:48 AM
by RED i really hope you are refering to your bike and not yourself in some creepy third person sort of way.
Steve
You guys are making me scared now  :o ....RED=ST4s. It was really late and I was drinking at Strokers (it's a bar, a bar, no not that kind of bar!!) and I was on the phone keyboard so it was really hard (stop it, I know what you're thinking  [roll] ) to text with one hand (D'oh!  [roll] ) and that was just what came out.  [roll]  ???  I give up...  [beer]
Cher
Very cool, Steve.  Glad to hear it is coming along  [thumbsup]   You know I heard about this Ducati ride this weekend...
Get goin'!   [evil]
Lisa
sdlrodeo
Can't rush greatness. But I will go as fast as I can. Gotta work weekends for a while. Been out of town a few days, hope I can remember how it all goes back together. After all, valves aren't THAT critical in a desmo are they?  ;D
Steve
RED
The confusion is brought on by jet lag in several different countries on several different continents I imagine  :-\
Take two of these,  [bacon] [bacon] drink three of those,  [drink] [wine] [beer]  get some sleep  8) and call me in the morning...er, U. S. time. hang in there.
sdlrodeo
IT'S ALIVE !!!!!!!!
Awesome! I got it all back together and didn't lose one part or have any 'extra' left over! Now I still have to sync the TBs and set the TPS. I'm almost done with my 888 rearset adaptation. I don't have the clip-ons on yet. Also, I'm planning on doing a Dzus conversion to the fairing. Bike should be done in a week or so. I did a lot of cleaning too.
Here's what I did:
Valve check/adjustment
Adjust belt tension
cleaned and refit crankcase breather with new o-ring.
Change clutch, brake fluid
Coolant change/flush.
Oil/filter change
Clean/degrease
Nice.
Steve
muskrat
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Ronr
Samsonite
sdlrodeo
Really it wasn't nearly as bad as I thought it was going to be. I thought it was going to be REALLY bad. I'll admit it was a little scary digging deeper and deeper into the bike. Of course having the fairing off wasn't a big deal. Nor was the tank as I've changed fuel filters before. I'd never taken off the airbox which entails the intake cones and of course you'll need to remove the radiator to get at the little 8mm bolt holding on the airbox. Since the radiator was off, well it needed flushing and so did the reservoir so that had to come off. Then it got a little more spooky when I took off the throttle bodies. Oh, yeah then the intakes, no big deal there. Take off the battery box and most connections so you can see what you're doing when taking off the belt covers. On the left side of the engine, take off the crank/timing cover so you can hook up your engine turning tool. Take out the plugs to ease turning said engine. Set horizontal cylinder to TDC. Now crack open the valve covers to see what you're working with. The exhaust side of the vert cylinder is a PAIN (nice words for the public forum). No way around it unless you want to take out the shock linkage. I tried. bigger pain to do that.
Once you find out what you need to change, go about changing it. And change it again, and again. After about the 3rd or 4th time of pulling the each of the cams since mostly the closers needed changing, it works. Button it all back up and give her a crank and hope she doesn't blow up!
Whew, I need a vacation.
Steve
Cher
