How to shoe-horn a Stebel Nautilus into M696
Started by ungeheuer, April 05, 2009, 06:46:56 AM
Quote from: ungeheuer on March 07, 2010, 02:19:34 AM
Or you could try Termis, Db killers removed.  Draws no battery power at all  ;D.
in fact adds power
DucatiTorrey
what if you already have that, and want more
  - real place
DucatiTorrey
#32
did your stebel come with a wiring harness? this is the cheapest i could find it
http://www.ecrater.com/product.php?pid=2587095#
doesn't appear to have a harness. do i just use the stock wiring?
TIA
EDIT: Also just noticed they have some new horns. The Nautilus comes in all black now too
http://www.stebel.it/stebel2009/default.asp?menu=news
  - real place
Nope, no wiring harness.  Its really not that complicated though (I just make it look like it is....  [laugh]).
BTW that funky red Stebel you have there isn't an air horn like the Nautilus, but its probably almost as loud....
Ducati 1100S Monster + Ducati 1260S Multistrada + Moto Guzzi Griso 1200SE
DucatiTorrey
ok good call, i checked out the sound clip on their site, i like the tone, just curious how big or small it is.
So, the nautilus uses the stock wiring? good to know.
  - real place
CCEMN1
Here's a size reference on my S4RS:
Not a whole lot larger than the OEM I removed from the same location.
"I try to be a warrior, like my heroes, and writing is just one blade on my Swiss Army Samurai Sword." Ken Kesey
Quote from: DucatiTorrey on March 23, 2010, 04:28:56 AM
So, the nautilus uses the stock wiring?.....
...Um... nope.   You supply your own wiring.
Quote from: CCEMN1 on March 23, 2010, 02:39:26 PM.....Not a whole lot larger than the OEM I removed from the same location.
A Stebel Nautilus is "not a whole lot larger than the OEM" ???.  Are you serious?  Thats like saying a Hummer is not a whole lot larger than a Mini.
Wonked
Just did this mod to my 695. Took awhile, but that horn will take your breath away. Great mod. Mounted it according to OP's method (though, the battery access is much easier on the 695).
Recommend installing with supplied relay.
Quote from: hihhs on February 25, 2010, 03:38:27 AM
Ungeheuer-
Did you ever find a good spot for a Stebel on your M1100?
Yup.  A Stebel Nautilus lives in the vast space where the airbox now isnt.
DucatiTorrey
stebel in my mailbox = check
wiring from ace hardware = check
connectors and relay = check
fuse and fuse holder = ummmmm
what do i do?  im doing the install sans the kit, all on my own, where can i get a hopefully black fuse box for one fuse?
  - real place
DucatiTorrey
question, without spending $20 on a multimeter, how do i know which original horn wire is positive and which is negative? ones purple, ones black. one comes from + battery terminal, one goes to horn button.
if i had to guess, purple is +...
thanks
  - real place
DucatiTorrey
ok so just checked out the bikes wiring diagram
the two wires from the horn are labeled BK and V
black and violet?
black goes to what seems to be ground, everything else has the same one.
V (violet?) goes up to the button.
i think i got it.
thanks
  - real place
Quote from: DucatiTorrey on April 23, 2011, 01:20:39 PM
black and violet?
i think i got it.
thanks
Sorry mate, I havent been keeping a close eye on this thread.  But yup, it sounds like you do got it  [thumbsup]
theprocess
Bump for an awesome tutorial...wiring diagram is a gem.  Thanks op! [thumbsup]
