January 10, 2025, 12:12:07 PM *
Pages: 1 [2]   Go Down
Author Topic: Carbon Fiber Veneer  (Read 5224 times)
adpeacock
ArmyDucRider
« Reply #15 on: April 15, 2009, 03:09:41 PM »
Hi all, here's those pic's.
That looks amazing, how wide did you make that stripe?  Did you use the veneer or make a mold on the tank?  Thanks for the great inspiration.
-2005Monster 620 Dark, Monsterparts Carbon Fiber Beer Tray, Pazzo Levers, Dunlop Qualifiers, CF Front Fairing
"Japanese Bikes are like supermodels; great to look at but full of aftermarket parts."
Mad Mal
« Reply #16 on: April 16, 2009, 12:11:06 AM »
No worrys.  Yeah havent done the tank yet, its next on list of things to do, thats why im leaving it to last, I havent desided to eather make a mold of tank or just stick C/B (carbon fibre) straight on to tank and paint clear to fill C/B, sand back clear, paint etc.
Stripe is 112mm total  with the thin stripes being 3mm wide.  /3/3/100/3/3/ if that make sense
 chug
07 S4R
« Reply #17 on: April 16, 2009, 05:19:45 AM »
 chug
Either way you're going to have a ridge at the edge that might be tough to fill with clear.
Maybe blend the carbon edge with resin?
rgramjet
« Reply #18 on: April 16, 2009, 05:29:43 AM »
Getting a straight edge without it looking frayed is tough to do.
You're obviously a crack smokin' redneck carpenter. Kiss
-Sofadriver
« Reply #19 on: April 16, 2009, 05:34:24 AM »
The actual edge of the carbon would be past what shows. The edge would be created by the tape line.
Mad Mal
« Reply #20 on: April 16, 2009, 02:27:44 PM »
Yep thats what I mean.
quote-The actual edge of the carbon would be past what shows. The edge would be created by the tape line.-quote
yep excatly There are edges with the paint any way
I just need a tank or something to practice on first.
It's still good riding wheather at the moment over here so I wont do the tank  straight away
Have a look at this, this sorta what I had in mind. How to cover parts in carbon fiber (fibre) by skinning or wrapping
 chug
07 S4R
« Reply #21 on: April 16, 2009, 03:08:23 PM »
It's a lot of work...
but it sounds like you know that.
Mad Mal
« Reply #22 on: April 18, 2009, 06:51:00 PM »
OK Curiosity killed the cat, started some experimental ideas on some plastic tube, first one basicaly same as youtuube demo, but the edges did stick up, I have sanded them down but could be a lota sanding doing the tank.
Next idea was same process as first but then put same gladwrap over carbon then wrap some duc tape around to compress resin and hopefully hold edges down as resin sets. Well the edges are down nice but have got a tape pattern in the resin.
« Last Edit: April 18, 2009, 07:55:43 PM by Mad Mal » Logged
07 S4R
Pages: 1 [2]   Go Up
