February 08, 2025, 02:04:31 PM
OZ monsters
Keeps stopping 'mid-flight'............
Topic: Keeps stopping 'mid-flight'............ (Read 4029 times)
Re: Keeps stopping 'mid-flight'............
Reply #15 on:
April 25, 2009, 11:19:04 PM »
Quote from: DUCMONROB on April 25, 2009, 08:19:14 PM
Ron once told me he had a similar problem on a Duke. He found the temp sensor on the front cylinder had water in the connections. Easy to get to and if you ride your bike in the rain or wash it too much this could be a problem.
See! _That's_ why I don't wash my bike! It's part of my pro-active maintenance regime! It improves reliability!
big
my personal website
my less personal (I'd stop well short of calling it "professional") web site
White Lion
Reply #16 on:
April 26, 2009, 01:06:42 AM »
Knew there was a reason why you didn't wash!!
Thanks for the heads up on the temp sensor.... Now where and what am i looking for? (i've never really ventured into the electrics of the Duc, only the mechanical bits) It has been raining a lot over the last week, and i've ridden nearly every day in it(See, not made of sugar
) So, there's a good chance water is the reason.....
: Cleaned the kickstand sensor today wasn't overly dirty
Question:
When i was checking things today, I noticed a big arse fuse a little bit loose. Not sure what the fuse is for. If you stand on the right hand side of the bike, and look at the battery, it's attached to the left of the battery. In it's own black housing. Pulled the cover off a found a 40a orange fuse that was half way in it's slot(I'm not sure if i dislodged it when i took the cover off though....)
loony888
"I WAS GOING HOW FAST, OFFICER?"
Reply #17 on:
April 26, 2009, 02:06:56 AM »
that is the main fuse for the bike.
make sure you have good contact between the fuse and the contact points, if you need to, use a small screwdriver to tweak them tight, if it was loose chances are that's your culprit.
paul.
HERE AND NOW 12 DIAVEL AMG
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
GONE BUT NOT FORGOTTEN 03 S4R 95 900SL
01 S4 93 900M
96 748SP
White Lion
Reply #18 on:
April 26, 2009, 02:34:01 AM »
Really!? What's the go with that one?
dragonworld.
I can make like a tripod with my.....
Reply #19 on:
April 26, 2009, 03:07:43 AM »
Ok, thats it !! Now I'm definitely paranoid !
I ride the DS pretty well every day rain hail or shine, with no probs so far. But I've got the 40k service coming up and I'm going to check out all the sensors and connections that are in the water stream!
Just in case of course.
White Lion
Reply #20 on:
April 26, 2009, 08:07:19 PM »
Possible fix guys.
Spoke to george at Flywheels, Again, he said it sounded like a fuel relay problem(He told me that last week, but i wanted to check all connections first)
Well, i went and grabbed a replacement($17). Plugged it in. Pressed start, and what did it do? Started first go, no delay. Did it again, started.
Put the old plug back in: Firstly didn't hear the fuel pump work(Unlike the first two times), then it just chugged along without starting. Tried it again, same result; no fire.
Plugged the new piece back in, started first pop. could be the goods.
I did notice that the points on the old plug were a little brown.....
[moto] Will let you know how it's goes after the commute tomorrow
mattyvas
Reply #21 on:
April 26, 2009, 08:23:50 PM »
It sounds like the self diagnosis and Q&A with Flywheels may have got the job done.
Hope it works for you, there is nothing worse than trying to diagnose a little gremlin.
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
White Lion
Reply #22 on:
April 26, 2009, 08:32:51 PM »
Damn straight there matty! I really do hope that's the problem, as i'm nothing but anal with this bike and i'll be pissed if it's something else.
On another note: visited Frasers today-never been to the new store- nothing short of amazing. Sales department, Peter, is brilliant. Although the parts man needs a personality.
Karla's been looking at a 696 for the last 6 months. Looks like a white one may be in the garage by the end of year(She gets her full licence in November). Today's little road trip to Frasers helped lengthen the shopping list by a few thousand dollars
loony888
Reply #23 on:
April 27, 2009, 12:18:52 AM »
shops that are willing to help diagnose problems with a customer are worth their weight in gold and should be supported as much as possible in all areas of their business. FLYWHEELS (sydney) do their share as do EUROTWINS (brisbane). I for one support eurotwins with tyres, batteries, services, parts etc, without looking elsewhere cause the $10 more i might pay for a battery is nothing compared to the amount i save from the helpful advice and support i get when i have a small issue that some shops want you to "drop it in and we'll get to it".
paul.
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
01 S4 93 900M
96 748SP
Dockstrada
Reply #24 on:
April 27, 2009, 01:13:22 AM »
Have you checked the little air censor behind the headlight , been told a simple bug can play havoc
If I wasn't who i was, I wouldn't be who I am !
DUCMONROB
Geez its getting hot holding my
Nothing like the sound of a Ducati!
Reply #25 on:
April 27, 2009, 01:28:57 AM »
Quote from: White Lion on April 26, 2009, 08:32:51 PM
Did you not know that it is a requirement when you go for a job with Frasers?
M1000SDS, ZZR1200, GPZ900R.
Gone:
900 Monster Special
S2R1000
998 Matrix
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
Reply #26 on:
April 27, 2009, 02:40:32 PM »
Quote from: DUCMONROB on April 27, 2009, 01:28:57 AM
The parts/spares guy at Ducati Melbourne....is.......frickin fantastic!
I know....I nearly fell off my perch!
bazz20
Reply #27 on:
April 27, 2009, 04:02:02 PM »
Quote from: Spider on April 27, 2009, 02:40:32 PM
if your talking about bob he,s a legend
Spider
Reply #28 on:
April 27, 2009, 06:07:27 PM »
Quote from: bazz20 on April 27, 2009, 04:02:02 PM
I certainly am...I kept wanting to say...."I don't get it, you know what's going on AND you work for NFI?
He's a legend!
DUCMONROB
Reply #29 on:
April 29, 2009, 02:23:00 AM »
Quote from: Spider on April 27, 2009, 06:07:27 PM
He's a legend!
Cherish Bob with love.
My spare parts bloke John is a little hard to draw a conversation out of him. Straight to the point! I suppose I am lucky that he does know my name!
Funny though, when you go to the other side they talk for hours about chrome and belt drives and chrome and saddle bags and........do I need to go on?
Gone:
900 Monster Special
S2R1000
998 Matrix
