January 10, 2025, 12:57:45 PM *
Pages: 1 [2]   Go Down
Author Topic: Can you say "BLANG BLANG!"? (some Rizoma and CF goodies arrive)  (Read 3105 times)
patorojo
« Reply #15 on: April 29, 2009, 06:43:21 PM »
Quote
um.... they do not require  bar-ends....  I dont understand why you couldnt mount the mirrors directly on the ends of the bars....  I wasn't prepared to do away with my tapered Rizoma bar ends coz I like em too much, but coz they are tapered obviously you cant mount bar-end mirrors on them.  Soooo I took 'em off mounted the mirrors directly on the end of the bars using the larger bush that came with your mirrors, and put the bar ends back on the ends of the bars!  Simple.  I have Rizoma grips though which are 8mm shorter in length than the original ones, giving me just enough bar end to bolt the mirrors on to..... Hope that helps, but its definitely possible to put the mirrors inboard of barends.... as you can see from my pics.
+1 what he said...  that is exactly what I did.  This shows mirror and grips BEFORE I installed bar ends.
Arne Berger
2007 S2R1K
2007 DL650
2005 DRZ400S
Grug
« Reply #16 on: April 29, 2009, 11:12:19 PM »
Well that's the same method I tried, but with the larger bush on my handlebars, the mirrors couldn't quite fit. They were VERY close to being able to fit, but the with the larger bush it was just too wide for the mirrors to be slipped/pushed on to the ends. I even tried going at it with a hammer (a towel protecting the mirrors of course) but it just would not go on. Sad That's why I had to mount them on the bar-ends.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #17 on: April 30, 2009, 08:32:30 PM »
You must have larger diameter bars than standard......  um... Huh?
Grug
« Reply #18 on: April 30, 2009, 09:57:30 PM »
Hmm... I think I'll try sanding/shaving down the larger bush a little, that should work. When the mirrors are so damn expensive it feels a little uncomfortable knowing they're not attached to solid metal.
Pages: 1 [2]   Go Up
