GPR Pipes?
Started by jagstang, May 17, 2008, 01:43:31 PM
Redlined50
Quote from: M900 on July 09, 2008, 05:47:35 PM
I picked up a pair of the high-mount stailess rounds and they fit relatively well.
The rubber sleeves are for the springs.
i also bought the same ones for my 2001 600 and decided that i did not like the way it was mounted so i came up with my own way so it does not just clamp to the frame. I also decided that it was not much louder than my cored ones so i took them apart removed all the the packing wrapped the core with some header wrap, secured it with wire and put it back together and now it sounds amazing  [beer]
M900
Quote from: Redlined50 on July 10, 2008, 02:38:25 PM
pics???
Redlined50
#32
Quote from: M900 on July 11, 2008, 05:44:20 AM
pics???
ask and you shall receive  [thumbsup]
Redlined50
Redlined50
Redlined50
its not finished or painted yet  :-[ but you get the idea  [thumbsup]
one bolt is where the stock heat shield goes and the other is on the old exhaust mount hole
M900
I did almost the same exact mount on mine, mostly because i did not like the empty screw holes where the old exhaust mount bolted into;
