S4RS Wheels to S2R1000 (New Idea)
Started by NAKID, May 16, 2009, 02:22:21 PM
aaronb
a thought... without having the wheel in front of me.  would it be possible to have 5mm milled from the mounting face on the wheel?
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
That would be more drastic than milling the fork bottoms and/or caliper mounts.
RB
#32
so if i read this thread correctly, the rotors stick out past the calipar?
I have gsxr forks, with the radial brakes. I had to get 3.5mm spacers machined to push the rotors out from the hub to align with the caliper. And a few other spacers to center the wheel on the axle correctly.
I have been looking to change out my wheels with the S4rs set-up also.
edit.....
i just read all 3 pages...for some reason the brain told me it was only one page.
NAKID...if it would help translate your issue to other folks that may be able to help, i would be happy to draw up (CAD) a document illustrating all of the dimensions you have found....pm me if you need this, i am going to just rework my gxsr spacer drawing, i would just need new measurements from you.
When looking at the bike from the front, the rotors have too much offset, meaning the stick out too far from the wheel and are not centered between the pads. In fact they stick out so far that the rotor contacts the caliper itself.
