Ceramic Coated Exhaust
Started by MsTek, May 29, 2009, 11:35:57 PM
WhiteStripe
Quote from: DrDesmosedici on June 23, 2009, 10:44:54 AM
Yes - Good Hues in Derry NH, right across the Street from Seacoast Ducati.
http://www.goodhues.net/
I can't stay enough good things about them, very reasonably priced and quick turnaround time.  [thumbsup]
Thanks - will give them a call.  Is powder coating and ceramic coating basically the same process?
2006 S2R 1000, Arrow CF exhaust, FatDuc 02, CF open cc with stock pp
ProTeal55
Powdercoating is just that (powder) that goes on dry and then is baked..
Ceramic Coating is a liquid that coats the part (usually exhaust) inside and out and then is cured in a oven (similar to Powdercoating)..
From everything I hear Ceramic coating is much more of a mess...
Member: Half Fast Chicago
Website:
moto
QD has come up with a ceramic coating that is thicker and more glossy than what we have seen in the past. They did a 1098 full system for our 10th anniversary. The finish is basically what they use on cookware. We will be offering this with all QD systems soon.
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
WOW those are GORGEOUS pipes...
ProTeal55
Has that bike had any miles put on it yet ?
I ask becasue usually glossy finish's will dull down with heat cycles..
Website:
dlearl476
I got my pipe back from Performance Coatings yesteday.. Fantastic.
moto
Quote from: ProTeal55 on June 27, 2009, 09:27:01 AM
No miles yet, but I've used several different ceramic coaters in the last 15 years- None of them came out as glossy as this.
This is thicker and actually looks like a ceramic coating whereas the others looked more like a powder paint. I'll shoot some pictures after I ride on it for a couple weeks.
I'm willing to take some time off of work to conduct this test...:)
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
MsTek
I am still waiting for mine to come back from the coaters so I can put them on.  Guess I'll need to get that damn power commander now too. =(
"Do something each day that scares you..."
mrplease
mine came back today...
FINALLY!
thruxton
Quote from: Perilo on June 19, 2009, 08:41:46 PM
A little more eye candy...$150 @ East Coast Powder Coating...looking forward to seeing your finished exhaust
i can't believe you sprung for those BSTs. if you did a "taste test", so to speak, would you be able to tell the difference?
thruxton
Quote from: ProTeal55 on June 21, 2009, 09:06:14 AM
Pic of my ceramic coated BoomTubes --->
i was thinking it was too black when i first saw your before/after pics. but nah, just fricken perfect! the boom tubes look so fantastic too. i am doing other things this summer (rizoma bling) but may swap out the termi set up i have for those (it's a big deal since i put $3g into what i have and it runs like butter).
pitbull03
Quote from: moto on June 26, 2009, 01:22:35 PM
Bad ass.
M1100S
996
ducrider45
I will be doing my pipes soon. It has been on the short list for a while. Flat black is what I will have.
Thomas Jefferson
Cider
I like that glossy color that moto posted a lot.  Here is the "titanium" color from Performance Coatings (the part underneath the engine; I've since coated the rest of the exhaust, but no updated pictures):
...and the "satin fresh" color from Performance Coatings:
Both colors are matte, but the coatings do seem to hold heat pretty well.  Unfortunately, they aren't any easier to clean than bare metal, and the coating is very thin, so you can't scrub them.  I've got a bunch of baked-on bug juice on the SV pipes, because there is a cricket/grasshopper infestation out here this summer.
superjohn
I had mine done in metallic silver, which I've not seen many people do. It does cut the heat a bit. When I change the oil, I only say "Ouch" instead of the expletive dictionary.
