January 24, 2025, 08:46:12 PM
Turn Signals!
Topic: Turn Signals! (Read 9178 times)
Mojo S2R
. Dark Mojo .
Re: Turn Signals!
Reply #45 on:
January 28, 2009, 05:08:24 PM »
Thanks.
Yeah, my bad. Micro not mini (fixed it).
Their bright enough I think but kind of small, but since I got the CA integrated taillight I just wanted something small that flowed with the tail. Be forewarned, I had to dremel the point a bit to get the shape right to blend with the tail. Just a bit of an angle on the forward point to match the shape of the tail then black silicone to fill in and smooth. I think they were actually about a quarter inch longer than I thought. I may have been able to mount them a little further back but felt they flowed better the way I mounted them.
My bike so far...
My desktop/wallpaper
CCMHA Map
Central Cal Monsters
hydra
life is analog...
Re: Turn Signals!
Reply #46 on:
January 28, 2009, 05:15:42 PM »
thanks for the tips.
you did a good job of trimming it cause it looks like it's part of the tail. IMHO that's the best light set up i've seen for the short tail.
did it come with a load box or resistor?
S4 Foggy- tires, battery...
BE WATER
Mojo S2R
. Dark Mojo .
Re: Turn Signals!
Reply #47 on:
January 28, 2009, 05:25:46 PM »
For how cheap the lights were they came with some very good quality resistors. Much better quality than the crap ones that came with the CA taillight. FYI. If you only install one set of LED lights you don't really need the resistors. If you install two or more sets, you only need one set of resistors. For example, I have LED Taillight, LED signals front and back and only have one set of resistors in the back and they are hidden under the tail. Hope that helps.
My bike so far...
CCMHA Map
hydra
life is analog...
Re: Turn Signals!
Reply #48 on:
January 28, 2009, 05:52:27 PM »
yes that does help!
thanks again mojo
BE WATER
Bellagio
Leo Vince pipes give me a
Live Fast, Die Young, Leave a Beautiful Corpse
Re: Turn Signals!
Reply #49 on:
January 30, 2009, 08:12:13 PM »
I just threw some universal (Lookheed Phillips I think) mini smoked front winkers on and still waiting on my tail chop kit to put the CA integrated LED tail on.
May your head gasket develop premature failure, your carb get gummed up, and your side stand fall short.
DarkStaR
Re: Turn Signals!
Reply #50 on:
January 31, 2009, 01:27:41 PM »
Cheapo LPs:
V3L3Z
Re: Turn Signals!
Reply #51 on:
January 31, 2009, 03:18:23 PM »
Quote from: DesmonsterS4RS on May 19, 2008, 04:43:23 PM
Cookies1 Tailchop, and Rizoma Track 01's they are 10x brighter than stock
you have to get the spacers from Rizoma in order for them to work with the seat cowl.
Hey by chance do you know who makes that cover you have for your bike.. and how much it is.. that thing is sickk. My Duc would love one.. lol
DesmonsterS4RS
"The Desmodromic Symphony"
Re: Turn Signals!
Reply #52 on:
February 01, 2009, 07:58:38 PM »
Quote from: V3L3Z on January 31, 2009, 03:18:23 PM
I sent you a PM.
07 S4RS, Full Arrows (CF), DP ECU, Open Airbox, K&N, Speedymoto Gold "Kukri" PP, Rizoma Clutch Cover, DP Gel Seat, Cookies1 Tail Chop, 14 Tooth Front Sprocket, CRG LS, Dyno Tuned by AMS 132rwhp, 74 lb ft.
