Why coffin reservoirs?
Started by mstevens, May 19, 2008, 05:27:15 PM
krista
Quote from: GRUBBY on May 23, 2008, 10:58:18 AM
pazzo levers
Aren't those the people that copied CRG?
A great all metal master cylinder comes off of a Kawi ZX6D. It was the 2nd generation after the original ninja 600. You can go to a motorcycle salvage yard and look for bikes with all metal master cylinders, then double check there are 2 calipers with 4 pistons each. And/or look at the bottom of the master cylinder for either 16 or 5|8 meaning is 5/8" bore size and will work with the brembo calipers.
I had one of those on my 900ss and really liked it. And then it went onto Zina's 900ss:
:) Chris
rebelpacket
#16
+1
I'm a poser, and I copied exactly what Chris just mentioned already.  I like the look of the coffin's on the monsters better than the goofy round or quadratic plastic doo-hickeys.  Works great, looks good, and is super cheap.
Privateer
And you can get pazzo levers which are pretty damn nice with my FHE with them and they make them to fit the older large pivot pumps. mu remote rez and coffin pumps, take the same levers.
Are there large pivot levers for the newer bikes?  I can't seem to really find any except for CRG and have to wrangle the doohickey to hit the clutch switch.
andy
MotoPsycho
After a certain year the pivot size changed to a smaller solid screw instead of a larger hollow one.
This is where I got mine at.
http://www.motomummy.com/store/product.php?productid=16140&cat=357&page=1
Follow the drop down boxes and find what you need. I like the short ones since my gloves bridge the 3rd & 4th finger and makes it hard to hold on and operate a lever at the same time.
