August 15, 2024, 04:22:00 PM
Maybe a derby, but IDC WHOA!!!!
Topic: Maybe a derby, but IDC WHOA!!!! (Read 2780 times)
Re: Maybe a derby, but IDC WHOA!!!!
Reply #15 on:
July 17, 2009, 03:21:48 PM »
Quote from: HobokenHooligan on July 17, 2009, 11:58:34 AM
not to spoil all the fun here but a jet ranger burns around 25-30 gallons per hour. Either than things got a big tank, or you cant go very far from home.
home is the interval between gas stops. it burns gasoline didnt he say?
is 25-30gallons per hour while the thing is mounted to a helo? id figure its about half that since you lost 70% of the weight
Reply #16 on:
July 17, 2009, 04:06:31 PM »
True, but it's not exactly moving around the same amount of weight as the Helo...
El Matador
Do I need knee pucks for my
Reply #17 on:
July 17, 2009, 04:16:14 PM »
Quote from: He Man on July 17, 2009, 03:21:48 PM
I seem to recall reading somewhere that it could burn any fuel.
Reply #18 on:
July 18, 2009, 12:18:44 PM »
in that case, theres more grease food chains then there are gas stations, i think youll be fine
tonkoshala
'02 S4
Reply #19 on:
July 18, 2009, 05:24:43 PM »
I'm thinking that if you have 180k to burn on a bike gas prices are not going to be much of a concern
Reply #20 on:
July 18, 2009, 05:29:21 PM »
Quote from: tonkoshala on July 18, 2009, 05:24:43 PM
I don't think he was commenting on the prices of fuel as much as the range of the bike...
darthmoto
.: 2009 M696 White :.
Reply #21 on:
July 18, 2009, 06:50:54 PM »
I wonder if you could turbo a turbine...
Scottish
Balls!
That's thinkin' with your dipstick Jimmy!
Reply #22 on:
July 18, 2009, 08:42:43 PM »
Quote from: animatronik on July 18, 2009, 06:50:54 PM
Have you met my brother? Sounds exactly like what he'd say.
Anywho, awesomeness, lots of awesomeness.
Airborne
Crash n' Burn
Monster S2R 800 - ALL BLACK
Reply #23 on:
July 19, 2009, 07:10:58 AM »
You can run turbines on many different types of fuel, this is true, although not necessarily ideal. It would probably run OK on pump diesel. True that its not lifting the weight of a helicopter, but it still burns ALOT of fuel even at idle and in low rpm range. I was commenting about its range.
I would have powered it with a Solar T62, puts out around 160 shp, burns roughly 12gph. Originally designed for a helicopter but used in a military generator since that project was scrapped by the government. One can be had for around $4k if you look in the right places...would make for a nice "little" project.
