February 24, 2025, 03:46:01 PM *
News: Please Help
Pages: 1 [2]   Go Down
Author Topic: Tail Bag question- almost embarrassed to ask  (Read 9220 times)
« Reply #15 on: July 27, 2009, 07:32:35 AM »
Pulling my leg back to my ass worked fine, it's a little painful but only for a minute.  As far as stepping on the peg goes, my dealer told me to never sit on the bike supported by the kickstand.  He said it was not strong like a japanese bike and would cause thousands of dollars in damage if the kickstand broke off.  Is this true?
Also, the bag says no more than 10 lbs in it.  How do they come up with this figure? I just weighed my bag with my lunch (and ice pack) duty radio, and back up firearm.  It weighed in at 11.5 lbs but I still would like to add some extra small tools. Do you think this is an issue? I was thinking off maybe adding a tank bag just for the firearm.  I would die if my firearm fell of the back of my bike and I didn't know until it was gone.  I am going to look for other options before I test this out with my firearm.
yeah the ducati kickstands are bolted to the engine case not the frame like japanese bikes. so if the bolts on the frame were to break the case before the metal holder bent.. you'd have a problem.
how big is your firearm? how about carrying it under the seat? there is a hollow area behind the toolkit. take a look you might be able to strap it to the seat somehow (secret compartment like)
sbui
« Reply #16 on: July 27, 2009, 07:55:18 AM »
28 inch inseam here.  With my bag on the back end I can't even thinking about swinging the leg over it.  I just step in to it, doesn't look pretty, standing on 1 leg , grabbing the anle and then twisting and setting the leg down.  looks horrible, but get the job done.
I would try carrying the backup firearm closer to you by the tank in the bag like you were thinking.  never know!!!!
"I reject your reality and substitute MY own!!!"
Goat_Herder
« Reply #17 on: July 27, 2009, 08:45:49 AM »
28" inseam here, it's tough but doable.  In addition to the suggestions on how to swing your leg over, stretching, keeping your leg folded, etc. you can also try grabbing onto your pants with your hand and pulling up a bit as you swing your leg over.  I always keep my left hand on the bars to steady the bike while I do so.
Good instruction.  Here's a video illustration on how to get your leg over, the quick and easy way.
P.S. I would stretch before attempting this.
Bruce Lee - Enter the Dragon super kick
Goat Herder (Tony)
Triple J
« Reply #18 on: July 27, 2009, 09:16:38 AM »
True. I also heard from a dealer this weekend that they have seen a couple side stands on the new bikes (specifically 848 and 1198) punch through the engine cases...caused by sitting on the bike with the stand down. The newer vacuum cast cases are lighter, and thus have thinner walls. Not sure if this applies to the 696 cases though.
z0mb1e_DUC
« Reply #19 on: July 27, 2009, 10:04:34 AM »
I'm almost certain I saw it in the 1100 brochure as using that vacuum casting method.  Haven't seen it mentioned anywhere for the 696.
'09 m696 Dark
WhiteStripe
Monster Addiction
« Reply #20 on: July 27, 2009, 12:15:10 PM »
Try this?
http://www.trampoline.com/14foot.html
2006 S2R 1000, Arrow CF exhaust, FatDuc 02, CF open cc with stock pp
« Reply #21 on: July 27, 2009, 12:32:35 PM »
I was avoiding a strap mounted tank bag as it seems like a pain for getting gas and heard they can scratch.
Get a Magnetic tank bag instead (unless you have a plastic tank) as long as you don't lay it down on the work bench with all the metal shavings and drill curly Qs it wont scratch your tank.
« Reply #22 on: July 27, 2009, 09:32:07 PM »
i used a strap mounted for the 2k trip i did. IF it had been made for the bike, i would say no big deal. i had no scratches and at times i was going more than 100mph. the fueling part for me was an issue because it wasn't made for my bike and the fueling cutout didnt line up. but most of the one's i've seen made specifically for a bike have a cutout in the right place. you just unzip the bag, like you would pull off a mag-bag.
golgofett
« Reply #23 on: July 27, 2009, 10:10:07 PM »
I ended up returning the tail bag and exchanged it for a Rapid Transit Recon 19 Strap Mount.  Kinda a pain to set up but I think much safer for what I need. For fueling, I can just undo the lower clip and flip the whole thing up.   I can deal with that.   The weight does feel different on the bike as opposed to wearing a back pack with the same contents.  Might take some getting used too.  I am a little worried about the weight closer to the front as I am already 210 lbs and have stock suspension.  I wish someone would come up with an easy and affordable fix for the 696 forks.  Haven't seen anything by Racetech yet.
Thanks for all the responses, especially the Bruce Lee video.
2009 M1100 Gloss Black
Motovation Frame Sliders
Touring Seat
CRG Lanesplitters w/Rhinomoto Barends
Rizoma fender eliminator
Rizoma Avio 21's
thruxton
2007 S4Rs
« Reply #24 on: July 28, 2009, 04:26:40 AM »
chug
KnightofNi
Lift my kilt to see my
« Reply #25 on: July 28, 2009, 05:52:42 AM »
always park near a curb.  Grin
i've had trouble getting on the XR when it's all loaded up. i always just put my leg straight over the bike or stood on the peg.
the monster has about 5 inches of standover height for me so it's not a problem. Tongue
causeofkaos
« Reply #26 on: July 29, 2009, 06:57:40 AM »
I had to test my idea before i posted, i was going to suggest doing a cartwheel onto the bike figured with enough momentum and your leg swinging down onto the other side of the bike would do the trick.At 9:30 last night i went for it. DO NOT ATTEMPT this moove while brilliant in concept i misscalculated and got the handlebar to my taint fell down hit my head
( not wearing helmet ) and blacked out. I was 3 hrs late to work this morning cause i was still in the garage and theres a wicked ringing in my ear......what was i saying. What day is it, Where am I??
Favorite convo i read on this board
"PICS OR IT DIDNT HAPPEN"
"F**K U IT HAPPENED"
Suzuki Blvd M109R " Sliver " = assassinated by cager
PW 696 " Pearl " = traded in
M1100 " Loki " = Viking God of mischief ( Goddess in this case )
Life is not a journey to the grave with the intention of arriving in a pretty pristine body, but rather to come in sliding sideways all used up screaming F*CK YEAH WHAT A RDIE!!
Pages: 1 [2]   Go Up
