Yet another Monster project(updated 7/26)
Started by Ducatl, July 31, 2009, 06:19:16 PM
Ducatl
Had some time to weld everything so it's all put together, I sprayed some red powder on it to get a feel for how it would look.  The bike will be red but I haven't found the red I'm looking for yet, it'll be something close to the color that powder is when it's dry. I decided to MIG the tubes and match the factory styling so they looked like OE ...aaannndd it was also less time consuming. That said, I've started construction on my own large PC oven, 6'x3'x3', so it'll be large enough for anything moto-related.
I'm really tempted to remove some of the plate gusseting for the shock mount area and add a tube to the open side of the plate. That's the only part of the frame that still really bothers me but after all of the damn sanding and filing for the frame caps I'm not sure I want to tackle the job,  Hopefully I'll do it by the time it's ready to PC.
As far as the wiring goes:
I actually put tabs on the inside of my frame tubes on my CR in it's first re-build many years ago.  I hated it!  It looked too...planned.  On a Monster, there's enough engine tabs and wiring loom to put everything out of sight w/o adding to the frame so that you can attach wires to it.
W/regard to running the wiring INSIDE the frame:  I'm sure it can be done...but why?!?  A carbed Monster is easy enough to hide wires on out of plain sight inside the frame w/o weakening the frame to run the wires out into visible sight just so you can route them inside the tubing.
The above is my opinion based on my direct experiences.  Thank you and go buy me some tacos & beer.   please?  8)
Ducatl
#153
Came across another AL swinger at a crazy price and had to scoop it up, They'll both clean up nicely.
frame is ready for PC at this point so the only thing holding me back now is the completion of the oven.  Hopefully soon ;D
