Advice on a monster 620
Started by mlop, August 03, 2009, 09:22:29 AM
mlop
I'm looking at a 2005 monster 620, and am considering buying.  Unfortunately it doesn't really have a service history.  It has 17000 miles and has had two owners.  I spoke with the 2nd owner, and he owned it since 8000 miles.  During that time, he never had belts replaced or a valve adjustment.  I don't know what kind of service was done the first 8000 miles.  The price is about 3200 before licensing.  Should I pull the trigger and go for it?  Also, this will be my first bike - although I have some cruiser riding experience.  3200 is at the top of what I'm looking to spend, so I hate to buy it and then be forced to have $800 dollars of service done.  Any good indicators of the wear and tear on belts or valves to look for?
Sorry, forgot to introduce myself.  I'm kris from ohio  [thumbsup]
Spidey
Welcome to the DMF, Kris.   [thumbsup]
In terms of price, the bad news is that you're going to have to pay for a 12k service (valves, belts, etc) not matter what.  While you can check what the belts looks like, regardless of their wear, they still need to be replaced every 12k or two years anyway.  The valves should be checked at 6k and there's no simple way that I know of tell if they're out of spec.  Alternatively, you can avoid paying for the 12k service by doing it yourself.  But I wouldn't attempt it unless you're mechanically-minded.  No matter what, it will take a while and you should still figure to spend at $100-$200 in parts though.
For a first bike, you may want something where you know more about it's history.  Also, make sure you figure the cost of buying motorcycle gear into your "first bike" budget.
GLantern
+1 to everything Spidey said. I would pass on the bike or tell the guy to have it serviced first before you purchase it, the bike needs to be checked out before purchase.  There are other bikes out there.....
"Just ride and never ever look back"
www.suspectsunlimited.com
Spidey
Oh, something else.  I don't know if you know this already, but the owner should have the red key and the key card.  Otherwise, he better drop his price another $1500 because you might run into issues with the immobilizer.  If you need, we can explain that in more detail, or a search for "red key" should produce some threads describe the issue.
mlop
Thanks for the quick replies!  I did check with the keys, and it does have the red key thankfully.  I was thinking about doing the service myself, because i am somewhat mechanically minded.  What else is done for the 12,000 mile service besides valves and belts?  Also, what kind of damage can be done to one of these engine by a worn, old or warped belt?
Triple J
Quote from: mlop on August 03, 2009, 09:55:23 AM
If a belt breaks you'll most likely end up with a valve through the piston.  :-\
Spidey
The 12k usually involves the belts, a valve check, oil change, brake and clutch fluid changes, spark plugs, fuel filter and general lubrication and checking of da stuffs on da bike.  If a belt fails, you're going to do serious damage to your engine.  The belts control the cams, which controls the valves.  The damage can be as small as a messed up valve or as large and a completely blown engine.  There are plenty of online tutorials to walk you through a 12k service and you can stop at any point and post up here and get some help.  Also, there are plenty of Ohio folks (dunno where you are located exactly) with a lot of Duc knowledge who might be willing to lend a hand.
I would skip this one-if nothing else, it doesn't sound like the current owner was real interested in maintaining it, which begs the question if it's ever seen an oil change.
Quote from: MrIncredible on August 03, 2009, 11:04:56 AM
Good point.  You're probably on the hook for plugs too (though that's only $10), and should have the fork oil replaced as well - since that's never been done. If you can do the forks, it's only about $10 in parts.  But if you need someone to do it, it is a couple hours of time in a shop.
Also, have a good look at the tires.  IF they are the originals, they are probably pretty shabby - and most bike tire manufacture strongly suggest that tires be swapped at 5 years of age regardless of millage.  A set of tires will run you the better part of $300, not including mounting costs.
Good that's it's got a Red Key - but you also want to have the code card.  Double check on that item of you decided to follow up negotiations
Scottish
From what it sounds like a sprockets set and chain may be needed too.
mstevens
Quote from: yuu on August 03, 2009, 11:19:15 AMAlso, have a good look at the tires.  IF they are the originals, they are probably pretty shabby
My stock 2005 620 rear tire had worn through right to the steel by about 3500 miles and the dealer suggested that was fairly typical. If this bike sill has the original tires at almost fourteen thousand miles more than that I would be shocked into insensibility. What would motorcycle tires have to be made of to get seventeen thousand miles on them?
Quote from: mstevens on August 03, 2009, 04:22:28 PM
It depends on riding style and rider weight and roads. The wifey could get 12k or more on a stock tire on a stock 695.
I could get 3k if I was lucky (more likely 2k) on a S4R.
I flog things, she doesn't, and I'm more'n twice her size. Such is life.
gregrnel
I bought an '03 620 back in February for $4200 with all the paperwork and 4500 miles, they're out there, just be patient. If you buy a neglected Duc, you'll pay much more down the road. I'd skip this one, unless you can pick it up for $2500 or so.
2003 620ie red, cored stock pipes, Hit -Air jacket, nice deriere.
mstevens
Quote from: gregrnel on August 03, 2009, 06:13:16 PM
Agreed. It turns out you can get an '05 with under 4,000 miles with all service records (at a highly-respected dealer) for a very reasonable price... ;)
redxblack
What part of Ohio are you located? I'd be glad to keep an eye out for you if I know what you're looking for.
