February 04, 2025, 09:54:39 PM *
Pages: 1 [2]   Go Down
Author Topic: Wheels: Powdercoating x Paiting  (Read 4464 times)
geoffduc
18 till i die
« Reply #15 on: August 07, 2009, 08:17:17 AM »
Nate when i had my wheels powder coated i removed the bearings and rubber seals before they were PCed and then installed new bearings +seals as the extra cost to my mind was worth it.
 coffee
2015 scrambler FT
2009 monster 1100s
ProTeal55
HalfFastChicago.Com
« Reply #16 on: August 07, 2009, 12:09:06 PM »
I would def. go the P.Coating route vs. paint.
I plan to strip and powdercoat mine sometime this winter (not sure what color/finish yet-need to spend some time on Photoshop Grin).
Plan is to remove from bike - tear down - blast the old/stock paint off and then powdercoat..
Member: Half Fast Chicago
Website:
jamanta
Tallest Monster rider in the world
Powered by pizza
« Reply #17 on: August 07, 2009, 12:23:48 PM »
i'll probably go the PC route since it is cheaper and more durable. can anyone tell me if i need to replace the bearings and such or can i just use the old ones?
 coffee
Cider
« Reply #18 on: August 07, 2009, 12:30:35 PM »
To remove the bearings, you have to push (or pull) on the inner race, which can damage the bearing.  Most people replace them for that reason.  I've replaced some and reused others.  You'll just have to see what condition they are in when they come out.
« Reply #19 on: August 08, 2009, 03:12:11 AM »
 coffee
That was the point of my post. Wink
When people compare costs of pc vs. liquid coatings they often fail to include all the variables.
Personally I wouldn't re-use bearings after removal because as others have said they must be driven out and the possibility of damage is high.
jamanta
Powered by pizza
« Reply #20 on: August 08, 2009, 10:28:40 PM »
in the end it will probably be the same thing. i may now just have it painted so i don't have to go through the hassle of remove the bearings, etc.
i'm going to try to get a better price from the painter Smiley
i will post images soon  Cool
« Reply #21 on: August 09, 2009, 03:02:30 AM »
My rear wheel had no bearings, but my front wheel does, i just left them in. Ive got about 3 or 4k on them since i PCed them. they feel fine, had them running at 90-120mph for 4 hours straight superslab with no issues.
Pages: 1 [2]   Go Up
