February 05, 2025, 05:03:23 AM *
News: Please Help
Pages: 1 2 [3]   Go Down
Author Topic: monster frame brace  (Read 14507 times)
truckinduc
« Reply #30 on: August 14, 2009, 06:58:55 PM »
I'm interested to see this unit pro-link setup, where is the attachment point for the lower dogbone going to be?
The attachment point will be the threaded holes on the case that is the original lower mounting point for the rearsets. Also where the kickstand mounts. Its the best location without actually modifying - welding the case, which I dont want to do.
truckinduc
« Reply #31 on: August 16, 2009, 07:52:34 PM »
frame is taking a slightly different direction
flanman
« Reply #32 on: August 17, 2009, 05:13:06 AM »
 popcorn I love all the progress pics  waytogo
loves ze desmodromics.
« Reply #33 on: October 13, 2009, 07:14:11 PM »
how's this going?
Monstermash
AKA-TomColore
Interferiscalo se potete
« Reply #34 on: October 15, 2009, 05:46:16 AM »
Very cool project!  waytogo
I know this may be slightly off topic because you're discussing the frame here but.....
Have you done anything to the forks from the RC51? By "done anything" I'm referring to changing out the springs to compensate for the HUGE difference in weight between the RC and the Monster.
A while back it was becoming popular to swap out the stock non-adjustable forks on Monsters to some from a GSXR. After doing a few I found there was a one problem that kept coming up. The forks from the GXSR were way too stiff because of the weight difference.
Not only did the bike itself weigh more but adding all the extra weight for the additional fuel the bike carries, the weight for the coolant (air cooled Monster vs. liquid cooled GSXR), and the fact that the weight distribution is much farther forward on the GSXR creates a big problem with the stock spring rates.
In this instance consider that the RC51 weighs in at a staggering 427.7 Lbs dry compared to the 380 Lbs dry of the GSXR and you have even a bigger problem.
IMO, just something important to consider if you haven't already done so.
« Last Edit: October 15, 2009, 09:14:52 AM by Monstermash » Logged
« Reply #35 on: October 15, 2009, 05:50:53 AM »
^^^ Good point.
Easiest way to figure it out is to try to set your sag.
truckinduc
« Reply #36 on: October 15, 2009, 07:46:25 AM »
No real progress, other than still designing in my head. At the moment I cannot afford the 4130 tubing I need to brace the frame and build the swingarm.
ONce the bike is done Ill re spring it accordingly front and rear. Im using a fox twin clicker out back with a hyperco spring.
Im also shifting as much weight forward as possible on this monster, but the bike should weigh about 370 wet.
Pages: 1 2 [3]   Go Up
