PLEASE HELP !!!03 monster dies when temp reaches 130
Started by moto-medix, August 07, 2009, 06:35:38 PM
moto-medix
I am now putting it all back together again so i can warm it up and do a compression check...the reason i suspected the valve was that i pulled the air box and could visually see backfiring into the front cyl intake. I will do a compression check and post results. thanks again.Ray ???
Lets chop it up ...and put that do dad on there...and this piece looks like it will fit...
moto-medix
ok...put the bike back together...added some lucas fuel injector cleaner and warmed her up. ran a little better...but pipes turned cherry red...still starts backfiring out front cyl. noticed a black oil-like substance on plugs new plugs). did compression check...150 psi in each cyl. going to check injectors now.
The pipes will turn cherry red if the bike is at high revs and not moving.  Of course, a lack of fuel will make things much worse.  Don't use more than the recommended dosage of injector cleaner.
