February 24, 2025, 11:47:14 PM *
Pages: 1 ... 18 19 [20] 21 22 ... 25   Go Down
Author Topic: *Show Me Your Clutch Cover & Pressure Plate*  (Read 177687 times)
NateNewThread
« Reply #285 on: August 20, 2011, 03:21:31 PM »
stupid question coming right up
so the people that have an open clutch cover on M696's have replaced their OEM wet clutch with a dry clutch?
loves ze desmodromics.
« Reply #286 on: August 20, 2011, 03:36:41 PM »
haven't seen that done on a 696 yet, not that its impossible, just likely that you've misidentified an M1100 as a M696.
NateNewThread
« Reply #287 on: August 20, 2011, 03:40:50 PM »
possibly. So I am guessing the 1100's use a dry clutch?
« Reply #288 on: August 20, 2011, 04:18:42 PM »
Not the newest one.  It used to be easy to describe which bikes came with dry clutches: All Ducati superbikes and any other models over 900cc.   Then the MTS1100 and 848 went to wet clutch, leaving that rule of thumb a poor fit. Now new Monster 1100 is also wet.
Uncle Mofo
"Must Win Track Day" Uncle Mofo Racing 2007 S4RS
« Reply #289 on: August 21, 2011, 05:05:23 AM »
Al Ducatis eventually will be wet Sad
                                   2007 red S4Rs
S4ROB
« Reply #290 on: August 21, 2011, 08:03:59 AM »
I have to  get something every time I go to Laguna Seca. This is what I got from Dan Kyle this year
"Guns. You think you have enough, until the ZOMBIES come."
Gunslinger's Journal
Destructobot
« Reply #291 on: August 31, 2011, 12:11:04 PM »
Just installed these today.  Barnett plate and Speedy 10 spoke gray cover.
Desert Dust
Ten Most Popular Uses for a
« Reply #292 on: August 31, 2011, 01:45:00 PM »
^^BEE-YOU-TI-FUL applause^^
07 S2R 1K:  "You are not special. You're not a beautiful and unique snowflake. You're the same decaying organic matter as everything else. We're all part of the same compost heap. We're all singing, all dancing crap of the world.”
DuctheMonster
« Reply #293 on: September 03, 2011, 11:12:16 PM »
Quick question on the EVR pressure plate set up... I have read that they come with plate bearings already installed... so does anyone have a good just quick spiel on how the swap is and how simple...?
StephenC
« Reply #294 on: October 03, 2011, 10:09:24 PM »
Here's mine, albeit a work in progress.  I'm waiting for the arrival of my Speedymoto 10-spoke cover (the same one as Destructobot - nice job!) and stainless springs.  I couldn't wait to try out the new Rizoma pressure plate, so it went on today and stays open for now.
Did anybody with the Rizoma and a 1100 need the spacers they supplied?  Mine didn't seem to but I haven't been on a long ride yet to really test it.
Ducati Monster 1100S (2009)
« Reply #295 on: October 03, 2011, 10:24:37 PM »
What kind of spacers?
Were they for the pressure plate itself?
Or were they for a clutch cover?
StephenC
« Reply #296 on: October 03, 2011, 10:36:40 PM »
Rizoma supplied 12 little metal spacers.  They are supposed to go between the spring and the end caps Rizoma supply, if the springs are too tight.  They increase the space between the ends of the six posts on the clutch plate (that poke through the holes on the pressure plate) and the outside of the end caps, to make that distance the same as the OEM fittings.  I didn't think they were needed on mine, but am a klutz when it comes to mechanical things, so thought I'd check here with those wiser than myself.  Diagram below:
« Reply #297 on: October 03, 2011, 10:45:33 PM »
Well...
First I've heard of 'em.
I suppose you could use them if your clutch were too light...  laughingdp laughingdp laughingdp
I guess that's what I get for buying my Rizoma pressure plate second hand.
StephenC
« Reply #298 on: October 03, 2011, 10:47:23 PM »
I would have thought the spacers would lighten the clutch, as they would lengthen the spring (i.e. decompress) so the pressure late would be under less tension.
CDawg
S4RS
« Reply #299 on: October 04, 2011, 12:54:23 PM »
If memory serves, whether or not one was recommended to use the spacers depended on the model and vintage year.  It was recommended for me to use spacers on my S4RS.  I believe they increase the spring pressure much like adding preload does to the rear suspension not reduce spring tension.
Pages: 1 ... 18 19 [20] 21 22 ... 25   Go Up
