Dual Sided Swingarms - Aluminum or Steel
Started by Travman, August 09, 2009, 04:35:07 PM
Quote from: Travman on March 06, 2011, 01:57:14 PM
Looks pretty cool.  The one in the first picture looks like a regular aluminum swingarm with the underneath bracing added.  The one in the second picture on the 851 looks kind of spindly in comparison.
Any luck contacting the seller?
None. Sigh.
COP TZR
back from the dead.....  Does anyone have any idea of the weight on the AL arm and the steel arm?  Curious to know the weight difference.
i believe the steel is lighter, but its flexy.
atomic410
also fitment is questionable with some exhaust systems.  I wanted to put an al on my 620 but the aarow high pipes weren't having it [bacon]
Team Atomic Racing  Check us out @  www.teamatomicracing.com
Thanks to my 2011 sponsors;
Motorex, Vortex Racing, Sidi Racing, Studio 299, Dunlop, Motoprimo, Caztek, On Track 4 Him, Fix Studio
2009 Framstad Cup winner
2009, 10, & 11 CRA 5 hour endurance race winner
CRA Expert #2
ZARS track school instructor
COP TZR
Quote from: j v on April 22, 2011, 01:24:01 PM
lighter...... are you kidding?
not at all.   I'm comparing the 17mm axle steel to the 17mm axle aluminum.
The box-shape itself on the aluminum is larger, and the thickness of aluminum is greater than the steel swingarm - hence its additional strength - there is also a lot more going on at the shock pivot on the aluminum swingarm than the steel swingarm.
The box-shape of the steel swingarm is narrower (and uses a slightly shorter axle because of it) and uses very thin walls, and the shock pivot location has lots of "open space" all around it.
I'm not taking my bike apart to weigh the aluminum swinger. ;D
I remember noting that the aluminum swinger I had to remove from the fixxer-upper M900 (it was damaged) was heavier than the replacement I had, which was steel.  I didn't measure either though.   I suppose I could get a rough measurement on the Alu M900 swinger, since its over at RichD's
I've got an late model (ST style) swingarm that I can weigh.
COP TZR
is it worthwhile to swap out a steel arm for an alum. one?  Other than the alum. being stiffer & I guess heavier, what are the advantages?
chris1044
Quote from: COP TZR on April 22, 2011, 11:11:17 PM
No, aluminum will always be LIGHTER than steel.  Always.  Rigidity depends on the types and the component design - I'm not sure, but in this case I would hope it's better than the steel component.
AL is what 1/3 the weight of steel with 1/2 the stength.
so figure to get the same stiffness you get about 2/3 the weight, but if you make it stiffer than... well you get close to the same weight or more.
so no, not always lighter.
Quote from: chris1044 on April 23, 2011, 05:32:27 AM
Only lighter per unit - like Raux said, it's over sized for the benefits of similar stiffness. It's also the older 851/888 design, where the steel design is sized like the newer big axle swingarms in box shape & thickness.
The steel swingarm flexes easily whereas the Alu version was super stiff. The Alu swingarm also has the big M10 bolt to locate the brake caliper bracket pin (also heavy) compared to the small welded-on pin in te steel swingarm. Advantage there is the Alu swingarms pin is removable for floating caliper setups. Other advantage to the aluminum, besides superior looks, is the built in spools!
Would I "upgrade" to Alu from steel? Yes, but it's a low priority - would rather save up for awhile and have a JMC or Metmachex made to my specs than hope for a good condition used Alu to show up on eBay for a reasonable price
Dellikose
Quote from: junior varsity on April 23, 2011, 08:25:52 AM
Sorry to resurrect this, but could someone please post a pic of the bolt through the caliper bracket? I'm reinstalling my aluminum SA and can't remember what it looks like.
1999 Ducati M900
Do you have the floating rear brake carrier (with the tension rod attaching at the motor) or the fixed rear brake carrier that is restrained by the pin in the swingarm?
