ECU Question for a Monster s2r 800
Started by TimJohannsen, May 22, 2008, 04:48:02 AM
CDawg
Quote from: He Man on June 13, 2008, 05:06:43 PM
Lucky you. :( non OEM ECUs not good for Stepper motor bikes.
If you can go this route, i would do it in a heart beat. its like a DP ECU and PCIII in one. you loose your immbolizer though. and you can get whatever custom gauges you want, if you want. =D Plus its tuneable by almost anyone.
+1  He Man's right...more everyday, I'm starting to believe DP ECU is the only flawless way to go for the newer mills.
