Motor swap 05 s2r
Started by karrotx, August 14, 2009, 12:58:05 PM
Porsche Monkey
How exactly does an output shaft get bent?
csp808
Quote from: Ducaholic on August 16, 2009, 09:56:23 AM
Poor workmanship during a repair perhaps?
karrotx
#17
Your guess is as good as mine. Contact <Name and location removed>; maybe he'll tell you what he didn't tell me ;).
<mod>
Let's not get into those kind of details please.
Thanks.
</mod>
woppini
If your concern is about needing a torque wrench, there are many other concerns  you should be aware of. I really suggest you get a knowledgeable buddy to help you through the process. Is this a proper diagnosis? I agree, how do you bend an out put shaft. If that truly is the issue, look at the engine case where the rear engine mounting bolt passes through the frame, through the engine.  The case can crack if its wacked hard enough. Even though youll be selling your engine, you might want to take a close look at that area to inform any new buyer.
GAAN
output shafts get bent when the chain is too tight
Quote from: Mother on August 18, 2009, 09:52:28 PM
not to mention gearbox gets all munged.
Aaaand the shaft bearings... and god know what else.
Quote from: ducatiz on August 19, 2009, 05:57:22 AM
Is that the technical term?
Quote from: NAKID on August 19, 2009, 06:23:39 AM
in english, yes.
in italiano, it is "tutti buffala"
karrotx
Thanks for all the advice!
Change of plans, I worked out a deal with Duc Pond - they will keep the old motor, do a full service on the new motor, and install for a good price. Total cost is still cheaper than $1826 and I get a fully serviced motor. I can't wait for them to finish!
rockaduc
Quote from: karrotx on August 21, 2009, 02:42:41 PM
How's it coming along?
karrotx
Quote from: yuu on August 24, 2009, 11:51:24 AM
They don't work Sunday and Monday - I'm assuming they haven't started. I'm hoping to get the bike back by Friday.
Cabbie
This bike's chain was the tightest I have ever seen.. SCARY tight..
So tight it bent the main.... poor thing.  But apparently, it's got a new heart as of today and is headed home
