February 10, 2025, 02:30:01 PM *
Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Oil Cooler (a different approach)  (Read 20802 times)
« Reply #45 on: October 06, 2009, 04:53:23 PM »
The problem with mounting it upside down is that a significant amount of air will  be trapped inside of the cooler. With the feed and return line at the bottom, there would be no easy way to avoid the air trapped inside.
i revisited this post -- it's not an issue, check out the MTS 1100's parts manual, page 80.  The MTS's oil cooler's intake/outlet are on the bottom.
The flow of oil is vigorous enough that it pushes the air out.  the oil cooler is a serpentine inside, not just an empty box.  all the air gets pushed right thru, no issues.
you can flip it right over if you like.  the air will not stay in the cooler when oil is flowing thru at high pressure.
loves ze desmodromics.
« Reply #46 on: October 06, 2009, 04:58:38 PM »
+1, this is how heat exhangers (oil coolers and the like) are designed. Its a back and forth 'maze' pattern.
truckinduc
« Reply #47 on: October 06, 2009, 08:49:39 PM »
I might be using an oil cooler from an airplane. They are a little different in design. Hopefully I can find one small enough. Maybe a hydraulic fluid cooler.
« Reply #48 on: October 07, 2009, 03:49:05 AM »
i've got about half a dozen coolers lying around trying to make one fit on my '95 900SP.  I want to move the cooler under the front cover, F1 style.  the biggest problem i've found is finding one off the shelf that's the right dims with something to mount off.
Bob Miller used to make a kit, but he's long gone from the biz..  Cry
« Reply #49 on: October 07, 2009, 04:15:08 AM »
under what front cover? front valve cover or front fairing?
« Reply #50 on: October 07, 2009, 04:17:38 AM »
DT mounted his up under the front fairing, I think it looks really good - would be great on a fully faired bike.
« Reply #51 on: October 07, 2009, 04:17:41 AM »
under the headlight, inside
Triple J
« Reply #52 on: October 07, 2009, 06:19:27 AM »
What type and size are you looking for? My Multistrada one is just sitting around gathering dust...it used to be mounted up front under the headlight, so it has mounting tabs.
« Reply #53 on: October 07, 2009, 06:21:30 AM »
narrow and thick..  needs to be the same volume but narrower than stock, about 6" max
there are a few brands out there, i just gotta find them.  got pics?
Triple J
« Reply #54 on: October 07, 2009, 06:24:53 AM »
I can take some pics and measurements tonight if you'd like. I think it's basically the same size as all of the newer oil coolers though...probably too wide, but I'll double check.
« Reply #55 on: October 07, 2009, 06:43:34 AM »
Question: Are you planning on mounting it to frame/steering stem or to the triple? I think mounting it to triple/forks would be problematic, with the lines constantly moving about (and getting extremely hot, potentially).
« Reply #56 on: October 07, 2009, 06:47:31 AM »
mounting it to the subframe that connects to the steering stem.  right under the headlight, hoses will run underneath and hang a little.  i've seen it done and it works well without impeding steering any.  the side covers hid the hoses.
YellowMonster
« Reply #57 on: October 07, 2009, 07:14:24 AM »
I have a friend with a 96 900 SS/SP (full fairing) that is running an oil cooler in that position (same cooler as stock) along with the stock cooler.  With both coolers here in the desert keep his oil temps in tune during the hot summers.  He just has a cover to restrict the one behind the headlight during the winter months.  A local Duc independent mechanic plumbed the lines and I remember correctly they are plumbed sequentially.  I will have to ask about it.
2002 M620
2001 748R
« Reply #58 on: October 07, 2009, 07:27:03 AM »
please do, although i don't want two coolers!.. sounds like he might have just used a small valve spring type..  they are narrow and thin, prob no more than 0.2 L capacity... i've seen one that is about the same width but is thicker with 0.6L capacity, which is about the same size as the factory one.
« Reply #59 on: October 07, 2009, 08:04:54 AM »
I've seen this, and I like the idea a lot. Here's the one I've seen, sequential oil coolers:
Pages: 1 2 3 [4] 5 6 7   Go Up
