Rear wheel install help (axle spinning can't tighten nut)
Started by tonkoshala, August 20, 2009, 02:24:07 PM
tonkoshala
BTW This is a pic of the side that was spinning. Just in case someone else runs into this problem...
Mine's never tried to spin, but yours does now.
Sometimes wacky shit like that happens.  :-\
Just for posterity, it's a 17mm hex in the end of the axle.
My MotionPro tool (as shown above, but the aluminum version) works in it.
tonkoshala
Holy make the beast with two backs I am the most lucky unlucky person on the planet....
My speedo does not work. I did a short run on the bike down the expressway. Handles GREAT defiantly tell an improvement all around, but......So I pull over to test out my speed by turning on the GPS on the phone. Smoke... [bang] [bang] [bang]
Not sure what the make the beast with two backs I did wrong but >:( >:( >:(
I'm taking it to the shop I am tired of dicking with it...........
tonkoshala
Quote from: Speeddog on August 21, 2009, 02:16:50 PM
Ack!  :o
Best of luck to you.  :P
Any idea what could have caused it? I checked and everything seemed to be sound before I took off. My guy is not going to be able to get to it until next Tuesday...These wheels I think are cursed!
My guess is you missed the spacer on the left side of the axle, but it's really hard to tell.
El Matador
Quote from: Speeddog on August 21, 2009, 08:10:38 PM
+1. I've almost missed that little make the beast with two backser twice.
Which maybe is why the axle nut wouldn't tighten properly?
DarkStaR
Is the rear caliper carrier scraping the rotor, and did the rotor bolts hit the rear caliper carrier?  ???
Maybe it's just the pic, but what's all the crap around the axle?  ???
Quote from: tonkoshala on August 21, 2009, 12:08:04 PM
does it look like his rotor is being shaved by the caliper bracket?
caperix
It kind of looks like the wheel bearing just came apart.  There are scrapes on the right and left side like the wheel has been rocking side to side.  Alot of movement if it broke the speed sensor.
tonkoshala
I did....it is off set over to the right pretty far...not sure what caused it yet....will update as soon as I find out....I was told that it might have been the wheel bearing.
I just really hope these wheels are going to be worth all of the trouble.  >:(
