My Duc died on me on the freeway
Started by ridingrabbit, August 21, 2009, 12:56:36 PM
ridingrabbit
ok truly frustrated [bang]
I purchased a new fuel pump from ca cycleworks, replaced my old one and nothing!!!! I traced the power coming into the fuel pump system and found I wasnt getting any power to the fuel pump so i traced the wires and found poor soldering (as well as a defective resin in which they were encased; the resin was actly crumbling off when i touched it) on the wire that enter into the tank (3 of the 4 were actly dislodged from their connectors, the only thing that was keeping them from touching each other was the resin in which they were encased. I resoldered the wires and re encased the wires in a new resin. reconnected everything and presto!! the pump kicks in. while i was here i reinstaled the old fuel pump and low and behold it works too!!! (while i was here i went ahead and put the new pump in). I reassembled the unit (triple checked all leads and connections) and reinserted the unit back into the tank, I connected all the lines and fired her up and now im getting a puttering then stall. I hear thee pump kick on. but now im stumped [bang]. My duck is starting to piss me off!!!!!
sitting by idle  [popcorn] while life passes me by....
Massinova
Your bike doesn't seem terribly old. ...Possibly you have a short some where which originally caused the to resin to deteriorate and the solder to partially melt, an its reoccurring?
1KDS
Do you have constant 12V to the new pump (with the key on)? If so put the old pump back in and see what happens.  The new pump is possibly DOA or the wrong one.
Every bike I've ever owned.
ridingrabbit
I believe the  deteriorating was caused by spotty materials the solder initially wasnt soldered in properly which caused the wiring connection to fail.I tested both pumps and they work fine, when I turn the key I can hear the pump start up. I took out the spark plugs and I can smell the gas and I see [gas] on the plugs so i know fuel is entering the chambers. I checked voltage and im getting current to the pump so thats not my prblm now. It seems im not getting any spark to the plugs. I pulled out the wiring diagram and now im chasing an electrical gremlin [evil] (someone mentioned a relay, does anyone know where its located on the 07 monster??? as i've said ive been trying to trail it down with the diagrm but all the wires are covered up).I havent really had that much time with my bike to do any mods with it so its all stock. I really enjoy my bike but this is really frustrating ??? esply on a bike that is a couple of years old. It seems everything happens after the warranty expired,..hmmmm
1KDS
The relay howie mentioned is controlling the pump so if you have power at the pump the relay is working.  Have you changed the fuel filter yet?
ridingrabbit
"THE DEVIL IS IN THE DETAILS" [evil] thanks for everyones input. as it turns out when i replaced the fuel pump and resoldered the wires i was soo fixated on that that i forgot to top off the tank :o my duc is back to purring "stupid riding rabbit" [bang] thanks all again!!! see you guys out on the road!!!!!
Quote from: ridingrabbit on September 23, 2009, 04:22:18 PM
So...
you were out of gas? [evil] ;D
ridingrabbit
HEHEHE well i filled up b4 the prblm and when i drained my tank to repair the wiring connections i  thought i left enough to start her up after the repairs,...guess i was wrong. anyways shes running like a champ now!! thanks to all for the advise [bow_down]
