ungeheuer 1100S - Rexxer ECU reflash + PC5 + AT100 Dual Autotune.
Started by ungeheuer, August 23, 2009, 11:42:53 AM
My Red/CF stripe DP tail cover finally arrived and so I had a CF front fender painted to match which meant it was time to slip back into the red again.  And as you can see, I finally got rid of the exhaust flapper too, soooo.... time to ride  [moto].
DucHead
DucatiTorrey
did you remove the termis cones to PC them?
  - real place
hcomp
Also, I noticed on the back seat cowl there is a raised section in the center that goes all the way to the back. Did you add it, or does it come that way when you get the DP carbon cowl? By the way, I love the paint on the front fender! [thumbsup] [clap] [bacon]
にã,,かかã,ã,‰ãšã€ç§ã®è»Šã¯æœ¬å½"に速ã,,ドラã,¤ãƒ–、私は女性のç"Ÿæ®–器のã,ˆã†ãªãƒã,¤ã,¯ã«ä¹—ã,‹
dennisd
YEA!  I'm likin' that front to back CF stripe.
DucatiTorrey
Quote from: ungeheuer on March 25, 2010, 05:55:46 PM
bling bling!
  - real place
Quote from: DucatiTorrey on March 26, 2010, 08:11:30 AM
I had the Termi end caps ceramic coated a while back, the plan being that when I found a way to dispense with the exhaust flapper-gate I would then have the rest of the exhaust system ceramic coated too (As I'd previously done on the 696 >>  http://ducatimonsterforum.org/index.php?topic=25025.0). But now that I'm at that point, I'm beginning to consider other options.....
Quote from: ryanracer on March 26, 2010, 09:49:58 AM
DP carbon cowl comes exactly as you see it, painted to match (its available in red, white or silver) with the centre carbon stripe raised up a little.
dennisd
What's the sticker on the right side frame tube?
Quote from: dennisd on March 26, 2010, 05:49:00 PM
I wish it was a sticker..... Its the "compliance plate" - a metal plate riveted to the frame, without which no vehicle can be registered in Australia.  Removing it is federal offence (although I have considered covering it with - ironically - red tape).
hcomp
Quote from: ungeheuer on March 27, 2010, 12:01:13 AM
Couldn't they have put it in a less conspicuous place?
Quote from: ryanracer on March 27, 2010, 01:29:52 AM
They're bureaucrats, of course they could've put it in a less conspicuous place, but then they wouldn't feel so important [roll].  Every M1100 and M696 in Australia has this thing in that very same place. I try to pretend not to notice it since there's nothing I can do about it.
DucatiTorrey
so much for peeling it off your frame and sticking it under your seat  [laugh]
  - real place
lazylightnin717
Ok i can't hold back anymore... I absolutely love the color combo! Everything is so perfectly balanced between red, black, and just enough gold. Perfect touch with the ceramic coated muffler tips [thumbsup] The ONLY thing that I am sure you have considered is the rear spring. And honestly, I don't think that I would get the rest of the exhaust ceramic coated. I like it just the way it is. Good job  [beer]
Comes a time
Says don't you see
Gotta' make it somehow
Quote from: DucatiTorrey on March 27, 2010, 04:52:01 AMso much for peeling it off your frame and sticking it under your seat  [laugh]
Oh sure, go right ahead - kick a bloke where it hurts  :P :P.
The exhaust emission, "e' compliance noise test and chain adjustment advisory stickers (all from the left side of the bike) I may already have put under the seat, but for the State road/traffic bureaucrats..... I deny everything  ;).  So, the compliance plate? As I said theres nothing I can do about it - no point me worrying about something I cant alter.
Quote from: lazylightnin717 on March 27, 2010, 10:42:35 AM
Thanks man  [thumbsup].  I have thought about having the rear spring powdercoated.... but so far the yellow isnt bothering me enough to get around to doing anything about it.
