February 11, 2025, 07:59:10 AM *
News: Please Help
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: 696 front suspension talk  (Read 22778 times)
devimau
« Reply #60 on: June 05, 2010, 04:54:27 PM »
Is this on a stock 696 ? On the 2009 I think it's impossible to set front sag (no pre-load adj.)
 Thanks
you can achieve this by replacing your front springs or by adding spacers to the springs, how much do you have now?
Link
« Reply #61 on: June 05, 2010, 06:00:39 PM »
Good point I wasn't thinking of replacing the springs but that would work, I always got the correct spring weight then would adj. sag with pre-load adjusters. It's the GF bike and I just started thinking about getting it set for her. I'll check it and see where everything is.
devimau
« Reply #62 on: June 06, 2010, 10:57:40 AM »
the best results will be having the perfect sag numbers with less preload on the spring, that'll make the suspension smooth.
lets say you have a .95 spring with 15mm of preload and 1.0 with 5mm of preload for the same sag number, I'd choose the 1.0 because being less compressed it'll be less reactive to road imperfections and will absorb them way better
« Reply #63 on: June 06, 2010, 06:37:19 PM »
i didn't think anyone made springs for the 696?
they have two different length springs.
devimau
« Reply #64 on: June 07, 2010, 07:37:27 AM »
depending what numbers he has that can be solved.
you can make a .9 into a 1.0 with a simple coil cut, not need to replace them.
Pages: 1 ... 3 4 [5]   Go Up
