February 18, 2025, 05:30:35 PM *
News: Please Help
Pages: 1 ... 7 8 [9]   Go Down
Author Topic: Arc Fabrication Titanium Framed Ducati  (Read 44069 times)
« Reply #120 on: July 15, 2010, 11:25:44 AM »
+1
Doesn't look like there was much penetration.
Look closely at the 2 pics.
By my eye, there's a sleeve/liner inside the Ti tube for holding the bearings.
The Ti tube is broken at the edge of the weld.
MonsterMan1036
« Reply #121 on: July 15, 2010, 07:11:57 PM »
Looks like the Ti on the head tube was just for cosmetics and there wasn't any penetration into the dissimilar metal (as stated above). That weld just pulled away. Shocked
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
The best kind of whore is a
« Reply #122 on: July 16, 2010, 01:45:15 AM »
The head tube was Ti with an aluminum liner pressed in for the bearings.
The weld broke right at the HAZ, a problem often seen on some stainless and apparently Ti as well. I notice it seems to happen more on brittle materials.
Preisker
« Reply #123 on: July 16, 2010, 06:58:14 PM »
OK, I'm not an engineer, we'll get that out of the way, right away.   But looking at that frame, in the first post, and in the crashed post, are some of those angles and joints kind of odd looking?   And from what I can see, there are a few not too pretty welds.    But as I said, I'm not an engineer, nor am I an accomplished welder.  The guy that built that bike certainly has a lot of go for it.  Ambition if you will.   Good luck.
« Reply #124 on: July 17, 2010, 02:08:01 AM »
You're right about the angles...Doug's design was very different from what you usually see.
If you see the welds in person they look great.
I'm not going to comment on the fact they broke in a crash.
I know that the bike worked perfectly during normal use.
It wasn't designed to crash.
« Reply #125 on: July 17, 2010, 03:53:36 PM »
Doug repaired my step son's fancy high line titanium bicycle frame that cracked.  The bike came back with perfect welding and alignment was also right on the money.
« Reply #126 on: July 17, 2010, 04:41:39 PM »
What brand frame was it?  Only asking because I'm surprised a high-end frame went belly up to begin with...
« Reply #127 on: July 17, 2010, 05:00:48 PM »
I don't remember.  One of the chainstays cracked in half.  I'll try to remember to ask.
Ducatl
« Reply #128 on: July 17, 2010, 08:51:46 PM »
Just to clarify I wasn't implying anything about the quality of the craftsmans or his work, it's surely a stunning and beautiful bike.
I've never welded titanium nor do I know much about it but I was under the impression that discoloration of the metal around the weld might be an indication that welds were contaminated. Perhaps somebody with titanium experience can actually chime in.
Or
Maybe it just broke because the frame was exposed to some ridiculously large force it was never designed for, like crashing, I could also believe that Grin
Pages: 1 ... 7 8 [9]   Go Up
