the all-in-one, superfantastic bar end MIRROR thread!
Started by M900, September 01, 2009, 06:50:15 AM
Tommysurfs
3rd eye, or something like that.  From a bicycle store, $15 and works great.  Save the $$$ for tires.
erik822
Quote from: cduarte on September 01, 2009, 05:19:09 PM
my bike came with a 2" CRG dental mirror which I really didn't care for, I took it off and put napoleons on both ends, I love them, they work well, have great glass and cost about $40 each.
I too have the napoleons and love them. I tried Monstrack Mirrors (look great, not curved so the view wasn't much), the tiny, 2" CRG (completely useless), mickey mouse mirrors (stock) and some stock ones from a newer monster. The napoleons were easily the most functional of the entire batch. No vibration at speed, clear and wide view.
Two wheels good. Four wheels bad.
rule62
Quote from: Scotzman on September 01, 2009, 05:47:06 PM
I just looked these up and wonder how you mounted them?
They come with 2 pieces of "stalk".  I only used the piece that puts the mirror "up" not the one that puts it further "out".  Adjusted them, tightened them up, and they're good all the way up to my bikes top speed.
yotogi
Quote from: Tommysurfs on September 01, 2009, 06:14:26 PM
I run these also, but am planning on switching to Rizoma Reverse Retros when I get the chance.
M900
Quote from: erik822 on September 01, 2009, 07:07:08 PM
How do you mount your napoleons? do you have the Napoleons down and in or up?  I've been considering them just because of the price and the size of the actual mirros, but I'd want it down (liek Industrialgirl's) and I'm not sure of it'll still actually work as mirros then...
erik822
I had them up and in. Then moved them to down and in and now have them up and out.
For the best visibility, wide side up and out is the way to go. They have a bit more curve and a slightly wider view that way. When I had them mounted in (which I preferred the look of) I got a wider view of my elbows and a narrower view of the road. Also when they were mounted up and in the interfered with my brake a clutch lever a tiny bit. Nothing to worry about, but it wasn't ideal. That wouldn't be a problem if they were mounted down and in, however.
erkishhorde
I like the Napoleons because they're so durable. I've had the bike down with them on twice and while they do mar up, as long as you can get the mounting bolt out, it's a typical bolt that you can find at the hardware store to get you running again. They're also very adjustable. Like erik and industrialgrl I've tried them both up and down. Down was convenient since there's almost no way to accidentally bump them but visibility was short. I've settled on up and diagonal in. Gives me clearance to split but I can still see plenty behind me. I also like the weight to them. They weigh more than any bar end so they help with vibrations a lot.
M900
Quote from: erik822 on September 03, 2009, 08:56:33 AM
Quote from: erkishhorde on September 03, 2009, 09:03:06 AM
garage space is at a premium, so I'd prefer to mount them down and in -- would thi give me more or less visibility over the stock mickey mouse ears?
Triple J
Way back when I had Napoleans mounted down. I thought the visibility sucked...much better when mounted up. In just makes it worse.
I'm bias though...I think Napoleans look terrible.  :-\
M900
Quote from: Triple J on September 03, 2009, 01:24:18 PM
mounted up, it'll smack into my car's mirrors in the garage, so it'll have to be down.   :(
If the visibility on the Napoleans when mounted down suck, I'd prob go with the CRGs or the Triumph Rizomas (whichever will work better)...
jamanta
i bought this set of mirrors on ebay for about $20 and i'm very happy with them. i can see a lot better than with the stock ugly-looking mirrors. these mirrors are about 3 inches wide and have convex glass which makes a lot easier to see. they don't look as cool as the rizomas but you can't beat the price and the quality is not bad at all.
Link: http://tinyurl.com/lpoefo
Good luck finding the mirror  [thumbsup]
erkishhorde
Quote from: M900 on September 03, 2009, 01:29:29 PM
See, that's the great thing about Napoleons. Adjust them for up and out and when you get home, just flip them down. As long as you grab it by the stalk you won't screw up your adjustment.
Bun-bun
Quote from: jamanta on September 03, 2009, 02:19:48 PM
I have these also. work well, don't shake, and can't beat the price.
psycledelic
CRG Blindsight 2" mirror.  Works great for its size.  Hard to distinguish  [leo] from a distance, but serves it's basic purpose and is about as minimal as you can get without riding without.
06 S2R800 - the wife                         [Dolph]
04 999s - the mistress
Michael Moore
Quote from: M900 on September 01, 2009, 02:48:50 PM
Does anyone have any experience with teh Obeon Streetfighters?  They seem to be the last expensive of the brand name jobbies....
Also, has anyone used the Triumph ripoff of the Rizomas?
I put a pair of the Oberon Streetfighters on my, well, Streetfighter. They're quite a bit smaller than the CRGs, and the glass is much flatter. The net effect of those two things is you have a very limited field of view. Plus they're not adjustable while on the bike - basically you use a couple of big set screws to get them in place, and there they stay.
Long story short, I pulled the CRGs off my Monster and the Oberons are sitting on my bench.
La nuova moto e il vecchio motociclista :: 2000 Monster 900 (il vecchio) :: 2008 Vespa GTS (doppio) :: 2010 Streetfighter S ("il PastaBusa")
