July 27, 2024, 03:16:55 PM
DIY Painting Tips
7
8
9
10
67
Topic: DIY Painting Tips (Read 395150 times)
Re: DIY Painting Tips
Reply #105 on:
August 25, 2008, 07:33:32 PM »
Cause buffing sucks.
Reply #106 on:
August 26, 2008, 03:28:37 AM »
Quote from: trouble on August 25, 2008, 07:33:32 PM
shush you...
all the grown up painters do it.
Reply #107 on:
August 26, 2008, 06:38:30 PM »
Quote from: ducpainter on August 26, 2008, 03:28:37 AM
shush you...
sneaks back into hole.......................................
Bbrent
'08 S4RS Tricolore
Reply #108 on:
September 03, 2008, 08:58:20 PM »
Ducpainter,
What gun and compressor would you recommend for a DIY first time painter looking to paint a tank and other misc. items. I've been told you need a compressor with atleast 3hp. Those are kinda expensive. Are there any other options?.......Oh, yeah, I'm poor too. Thanks.
Brian
Reply #109 on:
September 04, 2008, 03:23:32 AM »
Quote from: Bbrent on September 03, 2008, 08:58:20 PM
Ducpainter,
Brian
The compressor depends on the requirements of the gun.
3 HP would be too small, I think, as most economically priced guns require 17 cfm.
No matter how you cut it it's cheaper to have someone else paint your stuff than it is to purchase all the equipment.
If you're determined to DIY let me know and I'll make some recs.
Bbrent
'08 S4RS Tricolore
Reply #110 on:
September 04, 2008, 09:23:34 AM »
Quote from: ducpainter on September 04, 2008, 03:23:32 AM
Ok. One last question. I recently painted a spare tank I have with spray cans. I used all automotive paints and primer from an automotive shop and the tank turned out better than expected. Lastnight I rattle canned a coat of clear and it went on really bad. So, can I sand down the areas that are bad and take it to a paint shop for them to clearcoat. How does the sanding of the clearcoat work?
mojo
'99 M900S
Reply #111 on:
September 04, 2008, 05:10:58 PM »
It could be a laquer based clear, and if it is, A body shop will probably need to strip and start over. It is never a good idea to spray a urethane product over laquer...they don't get along very good and there is a good chance of having a bad reaction.
Some people are like slinky's. They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
Reply #112 on:
September 05, 2008, 02:10:28 AM »
There is very little lacquer available in rattle cans these days.
Almost all of it is enamel and is re-coat sensitive.
What do you mean by 'went on badly'?
Did the color coat lift, or was there just a lot of texture.
Chances are you waited too long to clear if there was lifting and the base will need to be sanded off and reapplied, or you could just wash the rattle can paint off with solvent and start over.
If there was texture/orange peel...sand it flat and reapply some color, then clear.
Bbrent
'08 S4RS Tricolore
Reply #113 on:
September 05, 2008, 06:49:50 PM »
Just alot of texture issues. Dimpling
Reply #114 on:
September 06, 2008, 03:05:08 AM »
Quote from: Bbrent on September 05, 2008, 06:49:50 PM
Use 600 wet or finer.
edit...
I looked at your thread in acc & mods...
Seeing as you used solid colors I'd sand with 1000 grit wet and clear...
you can skip the reapplication of color.
Make sure you clean the surface well after sanding. Use a water based product specifically intended for paint.
Last Edit: September 06, 2008, 04:03:14 AM by ducpainter
Reply #115 on:
September 08, 2008, 05:32:51 PM »
Quote from: ducpainter on September 06, 2008, 03:05:08 AM
Or locate some Sprayway Glass cleaner.
Reply #116 on:
September 08, 2008, 05:54:56 PM »
Quote from: trouble on September 08, 2008, 05:32:51 PM
That will work too.
The point being...
don't use a solvent based cleaner on rattle can products.
It would be ugly.
mmakay
695
Reply #117 on:
September 10, 2008, 08:50:14 PM »
I have some previously painted parts that I want to put a nice gloss black finish on, and I'm not sure how to proceed. I have a good airbrush set-up (and the parts aren't huge) so I want to save some money by just getting a gallon of decent paint off flea-bay or something. Some of it is plastic, so a complete strip job is impractical, but it needs to be primed and sanded anyway. I hope rattle can primer is good enough.
1) Does that seam reasonable, or am I wasting my time and money?
2) Are rattle-can primers compatible with single-stage urethane's?
- Mickey
Reply #118 on:
September 11, 2008, 03:35:18 AM »
Quote from: mmakay on September 10, 2008, 08:50:14 PM
Out of curiosity, how big are the parts?
I don't think you'll get a single stage out of an airbrush and get good results. Air brushes spray dry because of the small nozzle and all urethanes require a wet edge.
The rattle can primer won't bother the paint, but it in itself is a compromise.
mmakay
695
Reply #119 on:
September 11, 2008, 07:03:31 AM »
Quote from: ducpainter on September 11, 2008, 03:35:18 AM
The largest is a seat cowl. The rest is bits a pieces like clip-on mounts, etc.
Would a another paint type be a better choice? Or, I could just pick up a detail gun at Harbor Freight or Sears. I already have a 30gal compressor....
As for compromise ... well, I'm cheap, and I already have the cowl sitting here. If I really wanted to do it right, I'd just get a factory finished black cowl!
Realistically, the rest could be rattle-canned with acceptable results.
- Mickey
7
8
9
10
67
