December 22, 2024, 06:19:47 AM
DIY Painting Tips
20
21
22
23
67
Topic: DIY Painting Tips (Read 412674 times)
Online
Re: DIY Painting Tips
Reply #300 on:
May 20, 2009, 05:14:44 AM »
Quote from: WTSDS on May 20, 2009, 05:12:22 AM
I used a can of exterior house paint, an oil based enamel, labeled " aluminium " brushed on the front sump fins which had lost the coating
At first it looked too bright and silvery,stuck out like doggie dangles, but after a few thousand K's it has settled in nicely, the heat doesn't seem to be bothering it either
It really is amazing how cool our aircooled engines run.
You can get away with
almost
any paint on the engine.
fouramdesigns
Reply #301 on:
May 20, 2009, 06:39:57 AM »
DucPainter,
How do I/painter match up the stock paint? Having the frame touched up, tail chop weld closed/painted.
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
Online
Reply #302 on:
May 21, 2009, 03:09:00 AM »
Quote from: fouramdesigns on May 20, 2009, 06:39:57 AM
DucPainter,
There are companies that offer many of the colors. I usually start there and tint, or get a color scan done and do the same tinting process.
It's not possible to scan a frame though. Is it the gold?
fouramdesigns
Reply #303 on:
May 21, 2009, 04:43:04 AM »
Quote from: ducpainter on May 21, 2009, 03:09:00 AM
No, the Graphite grey.
Online
Reply #304 on:
May 21, 2009, 05:13:16 AM »
Check into Nexxa or Akzo Nobel. They should offer something close enough to tint.
Zaster
Only Pam can touch my
2007 S4RS (sold) , 2008 1098S (sold), 2013 1199R,
Reply #305 on:
May 31, 2009, 06:26:48 PM »
A buddy of mine painted the utter and the header on his monster with rattle can engine enamel. He scuffed the metal and degreased it. He gave it numerous coats with a 30 minute drying time in between. Several spots on the utter started to chip. Any ideas?
Is there such a thing as high temp. metal edging primer?
Online
Reply #306 on:
June 01, 2009, 03:17:41 AM »
Quote from: Zaster on May 31, 2009, 06:26:48 PM
I'm not familiar with a high temp etching primer.
He might have better luck using a higher temp rated paint.
Headers get really hot...hotter than most engine enamels can take.
Zaster
Reply #307 on:
June 01, 2009, 11:28:19 AM »
Quote from: ducpainter on June 01, 2009, 03:17:41 AM
What temp. range would the paint have to withstand ?
Online
Reply #308 on:
June 01, 2009, 05:38:52 PM »
Quote from: Zaster on June 01, 2009, 11:28:19 AM
I'd guess around 12-1500 degrees for a header.
Zaster
Reply #309 on:
June 01, 2009, 06:39:00 PM »
Quote from: ducpainter on June 01, 2009, 05:38:52 PM
Thanks Ducpainter,
I'll see what I can find...if I remember correctly BBQ paint
in a rattle can might match that rating.
scott_araujo
Reply #310 on:
June 02, 2009, 08:14:30 PM »
When I was into air cooled VWs I tried every high temp and BBQ paint I could find. None of them held onto the header right next to the exhaust port, too hot. They all flaked off. Also, they all tended to sort of chalk off over time and even on cooler parts where the paint held it would still tend to rust after a while.
Scott
pitbull
Reply #311 on:
June 05, 2009, 05:48:28 PM »
A couple questions for DP or anyone else who might know. I've got a 2000 900ie tank that I'm going to repair and repaint. It has the corsa (I think it's called) design with the checkered flag on each side and stripe down the middle. First question is, are the checkered flaga and stripe decals? I'm guessing yes. And, if they are, do I need to remove them to repaint or can I sand them down? I plan on repainting in a simple solid black..........perhaps matte black.
Thanks very much in advance.
Online
Reply #312 on:
June 05, 2009, 08:42:07 PM »
Quote from: pitbull on June 05, 2009, 05:48:28 PM
The checkerboard is painted....at least all the ones I've seen are.
Ducati has used two types of stripes. The S2R and newer are all vinyl.
The older M900 and S4 are painted with a vinyl border stripe.
That vinyl needs to be removed.
pitbull
Reply #313 on:
June 06, 2009, 03:45:48 AM »
Quote from: ducpainter on June 05, 2009, 08:42:07 PM
Your the best DP..........thanks very much
Tigermeat
Reply #314 on:
June 16, 2009, 12:04:06 AM »
Just wanted to share. I installed a Zard exhaust in the L/R High Mount. The bracket furnished for the left side was fugly bare ss w/heat discoloration from the cutting process. I surface prepped (sandblast) and coated with Rust-Oleum Auto gray sandable primer and top-coated with Rust-Oleum Auto High Gloss Cherry Red (209587). I wasn't expecting much for color match but was totally surprised at the result. The paint has been on about 2 weeks now and I can't tell the difference from the factory color under any type of light. Considering I coughed up maybe $10 for the two this is a great way to handle the little nik-nak jobs like maybe touch-up for tail chops.
Word of caution - having been a professional painter you will never get the quality / durability of a "pro" paint job out of a can.
Tiger
20
21
22
23
67
