Brake upgrade S2R 800 - done - WOW
Started by stopintime, September 08, 2009, 08:24:37 AM
cduarte
748 rotors will fit fine, I put them on my 695 and they worked.
DucLeone
well i got the Calipers from fleabay,got the rotors on the way from a fellow member here,now the master whad do i need to look for? i have the stock coffins as of right now (assuming 13mm) and i put pazzo levers on them a few months back,the coffin style don't really bother me (i'm not good enough of a rider to know the difference between coffin/radial and so on [laugh]).
i seen on yoyodynes website they carry coffin with bigger bore/piston whitch would accomodate my levers,what size would i need? and whats the difference in the brake lines do i need bigger line(diamater)? or can i use the ones i got?
Hope you can help me
Thanks Oni
DUCATI NON E UNA MOTO, E UN STILE DI VIVERE
KISS FRENCH AND RIDE ITALIAN
S2R 800 Black
Quote from: DucLeone on October 31, 2009, 05:39:38 PM
Thanks Oni
Your clutch master is most likely 13mm. Stock S2R800 coffin brake master is 15mm. I got a new 16mm coffin.
I'm glad I got the bigger master, it's firmer - the action is shorter and I like that. If you're on a budget it's not required - at least you can wait - then change it later if you feel the need. The 16mm looks excactly the same as the 15mm and will accomodate your levers.
In any case you should adjust the brake lever for the best/sharpest action - scroll down to the bottom... http://www.ducatisuite.com/leverchange.html
However, new lines are required. Yoyodyne-Fred made a custom set for me (~$120). The lines connect differently at the calipers, that's why. The ones I got have banjos which can easily be rotated on the lines - came in handy. Make sure the banjo to the master has the correct angle/bend - the one I got didn't and I was only saved by the cutouts in my SpeedyMoto top triple. My line has a T-split in the middle, like stock set up (only one line up to the master), but I think it's even better to get two separate lines all the way up to the master, where they connect to the master by a double banjo bolt (just a longer one). I had no room for that due to my PoorDucRider fairing stays. Check your bike for clearance before choosing this option.
It took me some time to figure out the best routing for the new lines, but that was mostly fun.
WARNING there's a very small plastic piece in the master - hidden in a hole in the master, between the brake light switch and the lever. It's very easy to loose if it falls out (took me 20 minutes to find it). Make sure you have it under observation ;)
If I'm being unclear - ask again. Done correctly you'll be VERY happy with the result [thumbsup]
DucLeone
 [clap]
i knew i could count on you to responde [thumbsup]
thanks this/you has ben very helpfull
Oni
S2R 800 Black
What?? No more questions?? There's GOT to be more....
[laugh] [laugh]
I'm just happy to be able to help [thumbsup]
Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
I followed that procedure (10 x 60/05 hard/panic stops)(x2) with cooling in between. The brakes smelled burned at the end, which I was told here could mean I overdid it. YMMV, but I had some minor hard spots as the result.
I scuffed the rotors with scotchbrite pads and break cleaner, did it over again, but softer - 8 x 50/10 once around. Haven't felt any hard spots since.
I'm no expert, but my guess is that stock Brembo brake parts shouldn't get the full treatment.
Ddan
I didn't see where you said what pads you're using, but if you've still got the stock Brembo pads in, you would see a big benefit changing them out.  I replaced the stockers on the Monster with DP street pads and was amazed at the difference, and I completely eliminated the judder I repeatedly got with the Brembos, no matter what I did to clean and bed them.  I went up one level when I put pads on the SS and they are better still, and no hot-spotting at all no matter how hard I'm using them.  I had EBC on the SS and the feel and bite on the DP's is way better.
Can you tell me more about the DP pads - parts # or links maybe?
I've only seen good explanations on CA Cycleworks.
Can you compare the DPs to one or two specific pads on the CA chart?
Ddan
http://www.dp-brakes.com/products.php#
Ducvet at Club House  http://www.clubhousemotorsports.com (look on the minor sponsors board) is where I got mine and he can give you the best options.
I had EBC HH on the SS, and I put on whatever DP pad is the most aggressive before the race pad (sorry, I forget the #).  The EBC felt like wood compared to the DP.  Very good initial bite, but not abrupt, and progressive linear grip from there.  Easy 1 finger tire howling.  The only downside is that now the Monster brakes feel like crap.   ;D
DucLeone
S2R 800 Black
The one ending in .86 shows as 'out of stock'.
erichan8757
07 GT1000
06 M620, [SOLD]
Modifications are never too many.
Even though the picture is probably the same, I think the difference is the size of the reservoir.
Later coffin-Monsters all (?) have the larger reservoir.
