February 07, 2025, 06:22:18 AM *
Pages: 1 2 [3] 4   Go Down
Author Topic: Rodent problem anyone?  (Read 3367 times)
KnightofNi
Lift my kilt to see my
« Reply #30 on: September 22, 2009, 09:20:03 AM »
The best was to put a potato in sideways, verse vertical.
You get a much better fit yielding better trajectory and distance.
god I loved that toy
we used potatoes that were slightly too large so they got sheared off on the sides resulting in a perfect fit in the barrel.
« Reply #31 on: September 22, 2009, 09:23:55 AM »
that is the way.  you can make a tamp with a mallet or small bat, just cut off the end.
good times, good times...
cyrus buelton
aka JuddDDDdd
« Reply #32 on: September 22, 2009, 10:13:34 AM »
I used an old broom handle as my ram rod.
I had a piece of tape that marked exactly how far to push in the potato, so it was right above chamber
I also experimented with wadding. Used newspaper. It actually worked pretty well.
1999 M750 (joint ownership)
2004 S4r (mineeee)
The best kind of whore is a
« Reply #33 on: September 22, 2009, 12:52:19 PM »
+1 to all of the above.
I built a few back in the day, and I always chamfered the ID of the barrel
Like .25 x 30* or 45* and that *forced* the potato to make a good seal.
The best gun I ever built had an adapter on the cleanout that would allow me to unscrew the barrel, and swap on a barrel of a different size or length.
The police own that one now  Cry
Half a frozen corn cob, thawed just enough so that the core was still frozen. . .
best ammo ever.
Evil
Also, I have 1/2 pvc water line in my garage in place for my air compressor.  Everyone told me it would burst and I would die with pvc chunks sticking out of my neck.  The pipe says 600psi on the side.
I don't think the joints will hold that, but it's been in service for 4 years at 110 psi
Grin
« Last Edit: September 22, 2009, 12:56:17 PM by Monsterlover » Logged
acalles
« Reply #34 on: September 22, 2009, 01:05:22 PM »
I've done quite a bit of experimentation with potato guns (I am from Nevada after all  cheeky). The best accelerant is ether (I think that's what it is anyway)...carburetor spray you get at auto parts stores. Aquanet is effective, but coats everything in nastiness over time.
Nahh..
the best accelerant is about a prescription bottle of black powder. as you can see in this pic we tried carb cleaner.
 Evil Evil Evil Evil Evil
I never found the potatoes after a black powder shot.. but the cops would circle right after firing.  we'd get 300 yards easy with carb cleaner though.
besides. for rodents the works best.  Grin
« Reply #35 on: September 22, 2009, 06:08:44 PM »
Nahh..
you make the beast with two backsers made a potato howitzer???
that's GREAT...!!!!!   bow down bow down bow down
Scotzman
Now that's thinking with your
« Reply #36 on: September 22, 2009, 08:10:40 PM »
We rapped a D battery in paper towels then duct tape, which would knock roof shingles off no problem.
I wonder if you could make a smaller one, trench coat sized. Most of ours had 5ft+ barrels.
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
« Reply #37 on: September 23, 2009, 06:45:01 AM »
Do you mean wrapped? Huh?
acalles
« Reply #38 on: September 23, 2009, 08:16:30 AM »
 Evil
1/4" think fence pipe, rabbit rear axle. end is capped off with a rear wheel hub (abut 3/8" thick) rabbit spare tire jack to adjust elevation, front rests on a empty mini keg (which was full when we started the project) then we ran a old hone down the pipe to smooth it out.
thats actually a older pic. its got a old cast iron fire extinguisher welded to the end now. we found the more chamber volume with less volitile fuel (like aqua net) we got way better results. using the black powder was kinda scary (it would roll back about 8" when fired)
Porsche Monkey
JuddDdd likes my
« Reply #39 on: September 23, 2009, 08:19:28 AM »
Evil
Yeah, that and you used an old fence post as the barrel. Tongue
acalles
« Reply #40 on: September 23, 2009, 11:53:53 AM »
It's thick enough, and way safer then the PVC potato guns.
the potato came out so easy I doubt it built up too much pressure and most of it was a boom and puff of smoke. It would get some serious distance though..
we briefly considered gun cotton or oxyacetylene, but decided either would be a really bad idea  laughingdp
we really wanted a sonic crack from a potato but never got one..
maybe some day I'll go back over it and try a different system to fire it with, and a longer barrel that'll probably help get some more velocity.
Porsche Monkey
JuddDdd likes my
« Reply #41 on: September 23, 2009, 12:01:46 PM »
One of my instructors for Porsche builds cannons as a hobby.  He is currently building one using one of the barrels out of an A-10.   Evil
KnightofNi
« Reply #42 on: September 23, 2009, 12:06:49 PM »
hehehehehehehehehehe  Evil
acalles
« Reply #43 on: September 23, 2009, 12:55:56 PM »
awesome.
and a bit more exotic then anything I had laying behind the shop. laughingdp
Scotzman
« Reply #44 on: September 23, 2009, 01:14:10 PM »
yes, we wrapped the battery, but we were rapping in the process of it. Huh?
Pages: 1 2 [3] 4   Go Up
