February 24, 2025, 04:36:17 AM *
Pages: 1 [2]   Go Down
Author Topic: confusion about my size versus my bike, feeling a bit nervous out there  (Read 1897 times)
ducrider45
Just Ride!
« Reply #15 on: October 01, 2009, 10:57:07 AM »
I rode a 620 for a few yeard at 230lbs + gear. The only issue I had was that I would go through clutch plates every season.
 Thomas Jefferson
Nakedsuperbiker
Moving Violator
« Reply #16 on: October 04, 2009, 10:20:57 PM »
Now I'm confused but it's late. coffee
If your bike has passenger pegs check the GVWR rating of your bike (sticker or manual).
Deduct you and your bike weight with gear on from that number and you know how much your passenger, bags, and her gear can weigh before worring about suspension since just about all bikes are built for 2 up.
Charlie in Surf City
2010 Streetfighter previously 2009 696
Arai Ducati Helmet, Joe Rocket UFO jacket Phoenix pants, Alpine stars boots, Shift Gloves.
Icon Mil-Spec backpack sometimes.
crazy bike girl
aka msincredible
« Reply #17 on: October 05, 2009, 06:29:27 AM »
Just because a bike can handle a certain amount of weight doesn't mean that its suspension is ideal for that weight.
loves ze desmodromics.
« Reply #18 on: October 05, 2009, 06:42:03 AM »
Precisely, The suspension is NOT set up for that weight. To think that it is because the GVWR is set high, or it has passenger pegs is incorrect.
The bikes are undersprung for the factory, being set for a single rider weighing around 160 lbs. "Being able to carry more than 160" is not the same has being correct. Correct suspension means sprung for your weight and the sag set.*
Ducvet will make your suspension work as best as your budget will allow, and you will be faster and more confident on the bike due to riding a more competent bike.  Spend the money on suspension first engine second.
Truer words were never spoken. You'll be 'faster' everywhere without any changes to the engine, and you'll hardly notice that you've gained speed through corners, because confidence will be higher.
There's been another post about a rider going two up and wondering why the suspension was bottoming out around turns. Well this is obvious, the preload can be maxed out, and it still not be putting the bike within the appropriate working range for the suspension damping circuit. Its all about spring rates. RaceTech and many others have calculators for this kind of stuff online, make sure to use it accounting for your gear (weigh yourself with gear on, its heavier than you think.) Changing springs is not all that expensive and followed with adjusting preload to set sag correctly, will make a world of difference in the handling of the bike.
* In regards to your weight. Damping characteristics are resolved with shim stacks, valving, and oil combinations.
Pages: 1 [2]   Go Up
