January 26, 2025, 11:11:11 AM *
Pages: 1 [2] 3   Go Down
Author Topic: Ducati may be moving its factory  (Read 4497 times)
« Reply #15 on: October 10, 2009, 03:16:41 PM »
What are the drawbacks & advantages of chain driven cams compared to belt-driven cams?
BTW, I found out recently that some people make fun of our belt drives by referring to them as "Hoover" drives (as in similar to a vacuum cleaner).
Advantage....Chains in an oil bath last forever...
Drawback...Everyone does it that way.
jmoth79
« Reply #16 on: October 10, 2009, 03:19:22 PM »
Only advantages.
Strength/durability, less likely to slip, resistance to wear, longer lasting, more robust,  ....noisier Evil
You are not a unique snowflake.  You are the same decaying, organic matter as the rest of us.
« Reply #17 on: October 10, 2009, 04:54:10 PM »
Some disadvantages of chains:
         More rotating mass.
         Require oil.
         Require more space required.  This also means more weight.
         Though they are maintenance free they do, at some point, break.
derby
« Reply #18 on: October 10, 2009, 05:09:27 PM »
         More rotating mass.
one would think two thin gears and a chain would be less mass than two inch-thick pulleys and a hefty, reinforced belt.
         Require oil.
plenty of that already floatin' around the motor (hopefully).
again, gear/chain vs belt/pulley...
everything breaks... eventually.  Grin
-- derby
'07 Suz GSX-R750
Spidey
Crashin' mofo
« Reply #19 on: October 10, 2009, 05:14:44 PM »
Just the cam chain on a Ninja 250 weighs a ton more than our Duc belts.
Also, if you have cam chains, you can't take off the covers and watch 'em spin (yes, I'm a guy that is easily distracted by shiny things too).
« Reply #20 on: October 10, 2009, 05:34:49 PM »
As Spidey said and my 40+ years of engine reair experience says, lighter
But you need to deliver it to the chain
Chain requires an enclosed, sealed case more than likely needing chain guides and a chain tensioning device plus provisions for delivering and returning oil.
caperix
« Reply #21 on: October 10, 2009, 05:53:05 PM »
I have heard that a belt requires less horsepower to drive than a chain, I'm sure the differance is very minimal though.  The current engine has been around in some form for a long time, theres only so much more reengineering they can do to it.  I would not be surprised to see them switch to a narower angle V in a future design to allow more compact chasis.
Gear drive cams are cool, the D16 uses them as does honda's RC51.  The sound is cool, not quite dry clutch and desmo valve cool, but it would be a nice addition to those sounds.  I don't think the bike would stop being a ducati if it didn't have belts and desmo.  As long as they don't build an inline four.
DanTheMan
« Reply #22 on: October 10, 2009, 06:06:15 PM »
Not sure what was wrong with the old place, it was close to the hookers. If you have ever been there you'll know what im talking about.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 M630ie Dark - Sold
2003 CRF175F
1996 Honda CR125R - Sold
« Reply #23 on: October 10, 2009, 06:25:21 PM »
What about the bevel drives?
jwoconnor
« Reply #24 on: October 10, 2009, 06:59:27 PM »
I would bet on gear driven cams. Less maintenance than even chains and they are usually reserved for "racing breeds" which would go well with the Ducati panache.
2007 BMW R1200GS Adventure
psycledelic
« Reply #25 on: October 11, 2009, 04:20:06 AM »
I am sure that Ducati would really benefit from a new, state-of-art facility.  Eco-friendly is a big plus.  Purpose built facility will really make their production more efficient.  Newer / better equipment means tighter / more consistant tolerances.  (Although, when all said and done, I wonder how much of the old equipment will just be relocated).
End of the day, I doubt the saving of efficiency comes close the equaling the cost of a new facility.  Which means belt driven, chain driven, and/or gear driven, the bikes are gonna be even more expensive in the future.
06 S2R800 - the wife                         Dolph
04 999s - the mistress
jerryz
« Reply #26 on: October 11, 2009, 12:17:43 PM »
gear drive cams will be expensive to produce ..ask Honda about VFR costs?...so not really a sensible way to save money.
jwoconnor
« Reply #27 on: October 11, 2009, 05:07:12 PM »
Getting out of MotoGP/WSB would save money but would that happen?
derby
« Reply #28 on: October 11, 2009, 05:42:50 PM »
i'm pretty sure marlboro picks up the tab for that.
-- derby
'07 Suz GSX-R750
Autostrada Pilot
« Reply #29 on: October 12, 2009, 06:03:03 AM »
Yes I do, and I have a picture to prove it!   [moto]
2003 Monster 620 Dark - Sold
1999 Monster 900 City - Sold
Pages: 1 [2] 3   Go Up
