Tools
Started by JDucati, October 22, 2009, 09:19:36 AM
WetDuc
Desmo Demon
#16
Quote from: JDucati on October 22, 2009, 09:19:36 AM
What other brand/type tools do you guys/gals use to work on your motor bikes?
My preferences are Craftsman because buying them is convenient and Proto because I get discounts through work at Grainger. The rest of my toolbox is full of Crescent/Xcelite (Cooper Industries) tools because I worked there from '94-'96 and some Stanley/Klein tools that I've gotten as gifts.
If money were no object, I'd have my tool box slammed full of Snap-on, Mac, and Proto tools.....well, older ones when they were really quality made (my father has a set of Snap-On tools from the early 60's). I know for a fact that some newer Snap-On tools are not as good a quality as you may think.......some of their products were made on the same manufacturing lines in our facility right next to Crescent, Napa, Grey, Armstrong, and a whole slew of other brands that we had contracts for. ;)
BTW, IIRC, Craftman's tool are (used to be) made by Western Forge and last I heard from an ex-boss, Cooper Industries is importing a lot of their products from overseas and the manufacturing plant I used to work at is pretty much just a shipping warehouse.
IBA #32735
Langanobob
Quote...Cooper Industries is importing a lot of their products from overseas and the manufacturing plant I used to work at is pretty much just a shipping warehouse.
Yeah, when you mentioned working there at the beginning of your post I was thinking that your old job is gone now.
I have a set of Crescent socket wrenches that are  made in Taiwan.  The quality is good, sad to say, probably better than typical US made.  And, now Vice-Grips are now made somewhere else.  I think we've not only lost the battle but the war, without even putting up a fight.
64duc
 I notice that no one mentions impact drivers. In 35 years as a mechanic I've found that the most reliable way to loosen allen head, phillips, or slotted head screws is with on of these.http://www.matcotools.com/Catalog/toolcatalog.jsp?cattype=T&cat=2247&page=1&#40520
94 M900, 64 Diana 250
Spidey
Quote from: iamhybris on October 23, 2009, 04:29:39 AM
Those ARE sweet.
Indeed.  They're soooooo worth the $.  Not a *necessary* part of a toolkit, but they're great to have.  I use them constantly.
Quote from: 64duc on October 23, 2009, 08:30:41 AM
+1.   IMO the biggest hassle with wrenching is stripped bolts/screws.  That's especially when you're starting out with a new bike because they loctite so many of hte bolts from the factory, so breakin' 'em loose the first time can be a pregnant dog.  And an impact driver isn't that expensive.
mojo
The only bad thing about snap-on/mac/cornwell, is that if the average home wrencher doesn't have access to a dealer, they are SOL on the warranty.  If you do have a local dealer, you can usually find a lot of hand tools (new and used) on ebay fairly cheap.
On a side note:  I once bought a set of metric combination wrenches from Sears (Craftsman) and the whole set of wrenches was defective.  The open end was a different size than the closed end, and neither end fit the fasteners right.  So, I'd use some caution when buying cheaper tools.
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
metallimonster
If you really want a good compromise between Snap-On Quality and Craftsman price look for Cornwell tools.  By far the best bang for your buck.  Most of my tools are Cornwell (including air tools) and I've never had a problem with any of them.
Agreed, particularly for motorcycles.
JDucati
Thanks for all the feedback guys... looks like ill be going with craftsman or cornwell.
Project I am starting is pulling off the clutch cover on a 03 m800 so I can get it powder coated.
~JD
2003 Ducati Monster 800ie Dark
dlearl476
After a lifetime of Craftsman tools, I've switched to Kobalt, a brand sold by Lowes.  Their sockets and wrenches use the "flank drive" concept that Snap-On does (Powerdrive to WURTH) that applies force to the sides of a nut/bolt rather than the corners.
The tools i use the most on my Duc are a set of ratcheting combo wrenches from WURTH and a set of T Handle allens from Bondus.
Langanobob
+1 on Lowe's tools.  And, as you can see in your picture, at least some of them are still Made in the USA.
are kobalt tools expensive?
mojo
QuoteTheir sockets and wrenches use the "flank drive" concept that Snap-On does (Powerdrive to WURTH) that applies force to the sides of a nut/bolt rather than the corners.
IIRC Kobalt is owned by Snap-On tools.
Langanobob
Quote from: He Man on October 27, 2009, 02:14:29 PM
About the same as Craftsman or Husky.  Not near as cheap as HF but better quality.
z0mb1e_DUC
price-wise, they are not bad.  I use a mix of Klein, Craftsman, WIHA, Kobalt, Proto & a few others.  Klein is a little pricey, but they used to be worth it.  Not so much.  Same with Craftsman.  I've got a 20yr old ratchet set from Craftsman & wouldn't replace with any of their new stuff.  Didn't know Kobalt was owned by Snap-On.  I will probably use more of their stuff, as they usually aren't that bad, both price & quality.
If anyone is considering an Impact gun, give a good look at the Ingersol Rand 231G.  You can find them for around $100.  Got mine at Lowe's with an air ratchet for about $130. They put out about 450ft/lbs forward, 500 ft/lbs reverse.  Unlike the cheaper CH units or some others, they'll actually work on lug nuts, frame bolts, etc.
'09 m696 Dark
