February 05, 2025, 05:01:06 AM *
Pages: 1 [2]   Go Down
Author Topic: 50mm for s2r 1000?  (Read 11646 times)
JustMike
« Reply #15 on: October 24, 2009, 09:24:09 PM »
OK, you're wrong, the 800, 1000 & s4r are 40mm stock from front to back period. they start as 40mm and are 40mm to the mufflers, (so you can use the marving with stock mufflers or slip-ons)
Model                #1      |#2      |#3         | #4         #5       |#6       |#7
S2R 1k            |  40mm |  NA    | NA        | 40mm   | 40mm  |  40mm |  40mm
S2R 800          |  40mm | 40mm | 40mm    | 40mm   | 40mm  |  40mm |  40mm
S4R                |  40mm | 40mm | 40mm    | 40mm   | 40mm  |  40mm |  40mm
the marving is 40mm it replaces the stock pipe & udder, the slip-ons are 40mm at the udder and 50 at the muffler, so this would be with slip-on's
Model             |  #1      |#2      |#3        | #4        #5       |#6        #7
S2R 1k            |  40mm |  NA    | NA        | 40mm  | 40mm  |  50mm |  50mm
S2R 800          |  40mm | 40mm | 40mm    | 40mm  | 40mm  |  50mm |  50mm
S4R                   40mm | 40mm | 40mm       40mm  | 40mm  |  50mm |  50mm
then this would be with full arrow or termi's ( I don't have termi's but I think they use the stck fron section of the collector as well)
Model              |  #1       |#2    |#3        | #4       | #5      |#6        |#7
S2R 1k            |  50mm |  NA    | NA        | 50mm   | 50mm  |  50mm |  50mm
S2R 800          |  40mm | 50mm | 50mm    | 50mm   | 50mm  |  50mm |  50mm
S4R                |  40mm | 50mm | 50mm    | 50mm   | 50mm  |  50mm |  50mm
after this i'm not sure what else to tell you....
I started with the marving & stock mufflers...(too quiet)
then got arrows (titanium) with baffles (still too quiet)
took out the baffles, good sound, loud!
them got CF arrow cans....louder yet...deeper sound
no pic yet...sorry
next should be Arrow collectors (50mm) front to back....
close to this....
Mike
turbowagon
« Reply #16 on: October 25, 2009, 07:22:16 PM »
Ok thanks! So theoretically the slip-on are interchangeable between s2r 800, s2r 1000 and s4r correct?
I just checked a vendor's site and looks like they are.
http://www.ca-cycleworks.com/shop/catalog/ducati/exhaust.html
Arrow Slip-ons, Pro-Racing, Titanium  S2R800 04+,S2R1000 05+, S4R 05+ 71662PR4
JustMike
« Reply #17 on: October 25, 2009, 07:58:23 PM »
I think thats right, here btw is the full Arrow system on an s2r 1000 *better than the last picture)
turbowagon
« Reply #18 on: October 26, 2009, 07:58:06 AM »
Thanks for the picture. I think the full system looks much better than slip-on. You should go full out and sell me your marving mid-pipe for cheap  Grin
After more research, I think the slip on for Multi 1000 and sports classic 1000 can also be adapted by S2r/S4R. That opens uop even more sections.
Pages: 1 [2]   Go Up
