December 21, 2024, 08:16:06 PM *
Pages: 1 [2]   Go Down
Author Topic: Throttle off-to-on transition in corners....  (Read 8541 times)
Smiling End
« Reply #15 on: May 31, 2008, 01:50:09 PM »
Your chain is only loosely connected to your motor.  It is the slop in that connection that creates the feeling of a tug just at throttle opening.  It's felt more when you have a really kinked chain.
Ah, gotcha.  Thanks for the response.
99 M750 Dark
55Spy
« Reply #16 on: May 31, 2008, 04:16:32 PM »
What I said holds true for the track and the street.  If you're still downshifting while already turned in, you're really going to unsettle the suspension.  The really nice thing about having a twin is that ok, you may lug a bit if you get around 2k rpm, but you don't lose all power.  Just stay on the throttle.
Thats why I love this forum you learn bits about all kinds of stuff.  Thanks for the inputs.  like the contact patch stuff that awesome.  BTW I was talking about slipping the clutch an dnot changing gears just using it to allow a change in the rpm.  its a hold over from riding 2 stroke dirtbikes most likely where I had a ton of RPM but not a bunch of torque
Ducatista
I don't need to brag about a titanium member.
« Reply #17 on: May 31, 2008, 08:17:06 PM »
Ahhhh... welcome to twins!  Decent torque, even when you're lugging along!  Don't worry about feathering the clutch to keep your rev's up, even if you're a gear too high.  If you're going into a 15 mph turn in 6th, that's another problem entirely.  But if you're one or even two gears too high, just stay on the throttle and she'll pull through just fine.   [moto]
carbon fiber Superbike front fender, bar end mirrors, floating cast iron rotors, carbon fiber chin fairing, Cycle Cat frame sliders, Arrow carbon fiber low mount slip ons, Rizoma billet cam belt covers w/ plexi windows, Rizoma billet front sprocket cover, billet handlebar clamp, carbon fiber rear hugger, tail chop, open air box, Corbin seat, stainless clutch springs w/ black keepers, suicideless sidestand bolt, Evoluzione clutch slave cylinder
www.myspace.com/bitgoddess
55Spy
« Reply #18 on: June 01, 2008, 01:34:59 AM »
I still hold all my old 2 stroke habits on my 4 stroke offroad bike too, they are just hard habits to break!  being over in japan now and riding 2 stroke street machines has just continued to reinforce them  Undecided
I love geting home to the states and riding the duc just don't do it enough and haven't found the right M400 over here to buy.  Not being able to keep a bike in a garage (space is a premium here)  and knowing that it will just rust has been another reason to delay the duc purchase in theland of the rising sun.
BOT
Lugging any V twin into a corner is way better than a last minute downshift, and drivetrain lash is exponentially exagerated in a bike without the proper suspension setup
Pages: 1 [2]   Go Up
