1123cc Big Bore Piston Kit for 1000DS
Started by Travman, October 28, 2009, 05:32:41 PM
DucatiBastard
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
You guys.
Looking forward to seeing the final products. And the final dyno numbers.
What will the bore/stroke dimensions be?
Imagine the torque! No need for a desmoquattro, certainly not as a street bike.
Well done.
greenmonster
QuoteI'm going with the 1123 kit with Pistal pistons.
[thumbsup]
Any headwork, how to mod ign/fuel?
M900 -97
MTS 1100s  -07
herm
Quote from: koko64 on January 11, 2010, 08:40:13 PM
The stroke will be unchanged.  I'm pretty sure the stock stroke is 71.5mm.  The bore will be changed from a stock 94mm to 100mm.  Here is what the pistons look like.
http://www.ducshop.com/product_view.php?cat=6&pid=303
Quote from: greenmonster on January 12, 2010, 02:22:12 PM
There will be head porting and a multi angle valve job.  The ignition and fuel will be taken care of by the stock fuel injection along with the Power Commander III that is already on the bike.  Donnie Unger will Dyno tune the bike and dial it in.
aaronb
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
1KDS
Every bike I've ever owned.
I'm not sure exactly.  I'd imagine it will be a couple of weeks.  Just got word today that my cylinders were being bored.  So things are moving along.   [thumbsup]
1KDS
Quote from: koko64 on January 21, 2010, 12:28:38 PM
You know I check this thread every day..  [popcorn]
I know it will be done by spring, probably a lot earlier.  I'll post as soon as anything happens.  Try checking once a week.
Rob Hilding
Head Work with minor porting and polishing is now done.  Four angle valve job has been done.  There is not enough resolution in this picture, but you can see all four angles up close.  The finished head is on the right.  The valves now sit up higher on their valve seat.
Not a very good picture, but you can see everything is shiny & smooth.
In this picture you can see the intake tract.  It is fairly straight for good flow.  (I got to see a bare Desmoquattro head while at the shop.  Now those intake pathways were arrow straight.  That is a big part of the reason they are able to make so much more horsepower.)
The exhaust exit is fairly straight too.
Front and rear heads sitting side by side.
I'm pretty sure we will get the bored and re-plated cylinders back fairly soon.  Probably sometime this week.  Pistal pistons are on their way from Italy right now.  Hopefully they will arrive soon too.
They look fantastic. I'd like to see some hi-res if you got 'em.
