December 26, 2024, 08:41:10 PM
1000cc in 2012
7
8
9
10
25
Topic: 1000cc in 2012 (Read 78341 times)
Spidey
Crashin' mofo
Re: back to 1000cc sounding more likely..
Reply #105 on:
December 11, 2009, 10:28:24 AM »
Quote from: gm2 on December 07, 2009, 02:10:30 PM
legalese.
<tingly (again)>
Spidey
Crashin' mofo
Reply #106 on:
December 11, 2009, 10:29:40 AM »
Quote from: gm2 on December 11, 2009, 10:22:40 AM
http://www.superbikeplanet.com/2009/Dec/091211a.htm
Is that it? Or is that a summary of the rule? Cuz there's gonna be a big-ass fight if that's all the rules says.
Edit: Ah, its' just a general rule so that they can get started on development:
“The main changes we have decided on are new rules for the MotoGP class,” added FIM President Vito Ippolito. “We will have four-cylinder engines, four-stroke of course, with a 1,000cc maximum. This base will give all the manufacturers the opportunity to start work. At the beginning of next year we will produce the new rules in a more complete format, but that is the basis. 2012 will be the year of a new era of MotoGP.”
http://www.crash.net/motogp/news/155290/1/new_era_for_motogp_as_1000cc_returns_in_2012.html
Last Edit: December 11, 2009, 10:34:54 AM by Spidey
derby
Reply #107 on:
December 11, 2009, 10:38:38 AM »
Quote from: Spidey on December 11, 2009, 10:29:40 AM
http://roadracingworld.com/news/article/?article=38940
-- derby
'07 Suz GSX-R750
click
here
for info about my avatar
Spidey
Crashin' mofo
Reply #108 on:
December 11, 2009, 10:50:17 AM »
I was asking specifically about the 2012 engine rule. It looks like they've just laid out the general standards and will get the technical rules in place (like they have for 2010 engines in the RR link) later down the line.
Reply #109 on:
December 11, 2009, 11:15:10 AM »
Max bore of 81mm, so max stroke 48.5mm.
Bore/stroke ratio of 1.67.
Gonna put the hurt on Ducati, taking weight off of the front wheel...
Spidey
Crashin' mofo
Reply #110 on:
December 11, 2009, 11:49:49 AM »
Quote from: Speeddog on December 11, 2009, 11:15:10 AM
I've heard generally that it's gonna hurt the Duc, but can you 'splain puh-leeze the part about the front wheel?
Last Edit: December 11, 2009, 12:02:24 PM by Spidey
Scooter-Trash
Reply #111 on:
December 11, 2009, 12:00:18 PM »
Area of the piston is pi * r
so max area is 40.5
x 3.14 or 515mm
With a max displacement (per cylinder) of 250, that leaves us with a min stroke of 250cm
/ 51.5cm
or 48.5mm
81mm / 48.5 mm gives us a maximum (mightily over-square) bore-stroke ratio of 1.67
(Just checkin' yer maths
The current bore/stroke on the 'Sedici (according to Wiki) is 104mm bore, 64.7mm stroke but this can't be right as this gives us a 2 liter engine. Maybe it's for one of their twins...
But at least the ratio is a similar 1.60, so it shouldn't hurt them too much.
Scooter-Trash
Reply #112 on:
December 11, 2009, 12:04:38 PM »
Hmmm, I also found the more reasonable bore/stroke value of 86x42.56 on the web.
That's 2.02 so I can see that being a big change for them
Reply #113 on:
December 11, 2009, 12:34:20 PM »
Quote from: Spidey on December 11, 2009, 11:49:49 AM
Longer stroke means the distance from crank centerline to the front of the horizontal cylinder head is bigger.
So, effectively the engine moves back in the chassis.
I can't find a pic of the GP09 engine, so I may be talking out my arse.
Spidey
Crashin' mofo
Reply #114 on:
December 11, 2009, 01:14:04 PM »
Ah, that makes perfect, simple sense.
I thought it was gonna be a bunch more complicated than that.
Scooter-Trash
Reply #115 on:
December 11, 2009, 02:16:46 PM »
Quote from: Spidey on December 11, 2009, 01:14:04 PM
Well, he didn't explain how the shorter stroke results in less space/time drag in the rotating Minkovskian reference sphere, leading to less graviton production around the centralized mass-space.
But his description is good for the lay-person
On a more serious note: Can anyone explain
why
they made the bore size restriction? Are they attempting to put a limit on how over-square (and peaky) the motors are? In other words, a round-about way to restrict output to a certain extent.
Or is it yet another 'switch from max 5 cylinders to 4 while conveniently dropping displacement by 20%' giveaway to a certain manufacturer who shall remain nameless (coughHondacough)?
Reply #116 on:
December 11, 2009, 03:25:47 PM »
Just an easy to enforce rev-limiter, as they've effectively decreed a minimum stroke.
I strongly suspect there will be additional rules prohibiting exotic-material pistons and rods, as that's the 1st engine-builder countermeasure against that kind of restriction to get more revs.
Reply #117 on:
December 11, 2009, 03:30:01 PM »
Quote from: Speeddog on December 11, 2009, 03:25:47 PM
why not just make it another spec class....
like moto 2?
Scooter-Trash
Reply #118 on:
December 11, 2009, 04:10:14 PM »
Quote from: ducpainter on December 11, 2009, 03:30:01 PM
like moto 2?
Please, never speak of this again.
They
might be listening.
Reply #119 on:
December 12, 2009, 07:48:09 AM »
A few more details:
http://www.motomatters.com/news/2009/12/12/more_on_the_motogp_rule_changes_6_engine.html
7
8
9
10
25
