The result of a busted belt
Started by Slide Panda, November 12, 2009, 06:36:14 AM
akmnstr
I had a head that looked like that.  It wasn't from a broken belt; rather, mis-timed valves.  I was on a test ride.  I pulled in the clutch and coasted down a hill then pushed the bike home.  At the time I was getting advice from V-2 in Australia.  I called them up and then sent them the head.  They filled the cuts and dents with weld and then shaped the head.  20K miles later and I am still using the same head.  It did cost some $$ but not as bad as I feared.  The big bore kit that I used to replace the trashed cylinder and piston was the most expensive part.
Charles Darwin
Quote from: akmnstr on November 12, 2009, 11:01:43 AM
...also the best part. I mean, unfortunate that it happened, but fun outcome.
DuciD03
oh those little scratches will come out with a little emery paper & elbow grease ...  ;D
.... all the world is yours.
akmnstr
Quote from: ato memphis on November 12, 2009, 12:06:33 PM
Yes, I've been able to turn every problem into an opportunity to gain a little more Hp and dependability.
Vroooom Vroooom [moto] [moto]
Charles Darwin
Quote from: akmnstr on November 23, 2009, 04:32:13 AM
we are like distant kin. something breaks (usually, *I* broke it...) time to upgrade.
