February 06, 2025, 10:58:15 AM *
Pages: [1] 2   Go Down
Author Topic: Frame Color  (Read 4275 times)
hackers2r
« on: November 24, 2009, 09:38:51 AM »
Are the S2R frames painted or powdercoated from the factory?  Looking to change colors and want to do it the right way.  Thanks.
« Reply #1 on: November 24, 2009, 11:40:49 AM »
you could PC or liquid paint them. PC is just paint without a liquid medium. Though the material is ultimately what makes PC more durable. There certainly are liquid paints that are close to or as durable as PC, but it comes at a higher cost. Liquid paint almost always has a better gloss factor and finish.
hackers2r
« Reply #2 on: November 24, 2009, 12:19:56 PM »
Found out from my dealer that they're PCd
Ducatl
« Reply #3 on: November 24, 2009, 05:53:48 PM »
I...was under the impression they were painted?
« Reply #4 on: November 26, 2009, 11:40:50 AM »
I think it is painted, but this is just my hunch based on repairing the nicks.
jwoconnor
« Reply #5 on: November 26, 2009, 11:41:43 AM »
I don't think they would bother with the labor of liquid paint unless they were doing some short run metallic or candy colors.
2007 BMW R1200GS Adventure
« Reply #6 on: November 26, 2009, 02:07:35 PM »
The wheels are also liquid paint.
ProTeal55
HalfFastChicago.Com
« Reply #7 on: November 27, 2009, 07:50:28 AM »
Last I heard the frame was PC'ed and the wheels were paint..
Member: Half Fast Chicago
Website:
« Reply #8 on: November 27, 2009, 05:29:32 PM »
I agree with them being painted. Seems too thin to be PC...
Bharuch
« Reply #9 on: February 09, 2010, 06:40:43 PM »
 Roll Eyes Is it easy to remove the frame to change the color? I like the red 1100 but I am afraid it the red frame will not look very good with various colour therapy kits.
hackers2r
« Reply #10 on: February 11, 2010, 02:04:59 PM »
So an important question. Can powdercoat be metallic?  Never thought there was such a thing.
MotoCreations
« Reply #11 on: February 11, 2010, 02:37:21 PM »
Yes.  But talk with your powdercoater you are going to use first -- some do industrial (one color) whereas others are into the funky colors, overlays, metallics, etc.  Make sure they have done it before!
I've seen some four process PC done in the past.  Base coat, metallic, toner (fade) and then clear.  Really thick looking though -- so make sure you like that look.
For most factory Ducati frames, I usually do the following: tinted base/primer (heavier to fill the welds) followed by the final PC color itself.
I've also taken frames from the PC AFTER the first thick base/primer and then brought them back to shop and wet sanded to blend things better.  Cleanup and bring back and let them do final PC coat.  A bunch of SoCal custom car builders do this trick on chassis as it blends welds for showcars quickly and without much labor.  Some just paint over the PC itself if they can't get the right color PC mixed.
Also you can get "color matched" PC colors made.  Just bring a sample and they can route back to Cardinal or other supplier and get made.  I think it was $35/extra last time to get color matched PC mixed.  I've had very good luck in matching solid colors.
hackers2r
« Reply #12 on: February 11, 2010, 03:02:16 PM »
Well the main reason I asked was to try to deduce whether my frame was powdercoated or painted.  However, I think powdercoating is the better option due to durability.  Any advice?
MotoCreations
« Reply #13 on: February 11, 2010, 03:12:37 PM »
most Ducati frames are painted.  Usually a primer/etcher followed by paint. (that is baked to make more durable)
Paint -vs- powercoat?
I paint all my frames.  Mostly because I know I can easily strip if needed if I make changes later ala welding, more modifications, etc. I can spot it in easily enough.  I also "crack check" (magnaflux) my personal cromoly frames (ala racecar suspension parts) at times and thus the paint needs to be stripped to do so.  I honestly think I'm the only person who does this -- but it's what we did in the racecar world and it's hard to break the habit.
Almost every customer frame is powdercoated -- simple because they won't be modifying their frames and want long-term durability.
hackers2r
« Reply #14 on: February 11, 2010, 03:34:32 PM »
Paint it is then.
Pages: [1] 2   Go Up
