February 05, 2025, 10:17:02 PM *
News: Please Help
Pages: 1 [2] 3   Go Down
Author Topic: Rizoma Indicator 'Black Box'  (Read 13102 times)
loves ze desmodromics.
« Reply #15 on: December 07, 2009, 09:24:30 AM »
From PJ'S Website:
Quote
Installation Note: DO NOT install this signal without the load box that is wired to it. It is required to convert the current to 6 volts. Not intended to be used as a running light, this is a single element signal.
« Reply #16 on: December 07, 2009, 09:24:44 AM »
It wasn't a problem to find space for their mile of wire, but it looks cluttered to me.  I would love to see daylight through that space.....
+1
geoffduc
18 till i die
« Reply #17 on: December 07, 2009, 10:17:24 AM »
From PJ'S Website:
Thanks ato memphis, its the first time that I've seen that info  waytogo
 coffee
2015 scrambler FT
2009 monster 1100s
« Reply #18 on: December 07, 2009, 10:20:45 AM »
If it wasn't on his website, I was about to pick up the phone and call him, because I could do without them in the front, I would. I want it as "airy" looking (supra) as possible.
Bill in OKC
S4Rs
« Reply #19 on: December 07, 2009, 11:10:05 AM »
I wish they still produced the old rizomas that didn't need the load box.
+1  I like the way their signals look, but that load box is a deal-breaker.
ollie
« Reply #20 on: December 07, 2009, 08:23:03 PM »
I'm not sure this will be a big help, but I bought my track-77's from PJs, and at that time (before buying) I asked them about the black boxes (because in the latest Rizoma catalog there is a picture of a new black box (or resistor?) which I haven't seen before) and they said that the packages vary now (old style and new style). My signals all looked the same, though: I had the lights, the black box (which was just a very flat 1 1/2 inch thing) and two resistors (same length as the black box, but rectangular cross-section). And yes, the load box was wired inline.
This sounds like what is going on,
I think I have one new style with the 'black box' unit a similar size and shape to the resistors and one old style with the chunky black box.
 I wonder if you can buy the the new slimline 'black boxes' as a seperate item, they are certainly much easier to tuck away
« Reply #21 on: December 07, 2009, 08:31:20 PM »
I hope the new ones aren't as big as the one i got. I'd order if they had decreased in size, its too damn hard to hide the big ones when there's alternatives that are box-less...
ollie
« Reply #22 on: December 07, 2009, 08:39:11 PM »
the new ones are about the size of the resistors,
Sucks that they sent me one of each bang head
hunduc
08 S2R1K
« Reply #23 on: December 08, 2009, 09:15:05 AM »
I am not absolutely sure, bit I think these are the new load boxes:
and on this picture you can see how the resistors look like:
I guess I did not say anything new at this point. It might be possible to buy a separate load box, I would contact PJ's. They have unbelievable customer service, they might do something for you.
corey
'06 Tang/Black S2R800
« Reply #24 on: December 08, 2009, 10:02:40 AM »
so much nicer.. they now at least have a make the beast with two backsing mounting hole...
asshats.
battlecry
On a silver black phantom bike...
« Reply #25 on: December 08, 2009, 01:40:58 PM »
Aren't those boxes there to change the voltage?  If so, there may be other ways to do so.  A different dc-dc converter, a voltage divider network (two resistors or a potentiometer), or a zener diode could drop the voltage.  Ato, can you measure the voltage across the leads after the box?
« Reply #26 on: December 08, 2009, 01:56:52 PM »
Well, as the site says (Going off of PJ's), the boxes change the voltage down to 6v, stock systems run at 12v I believe.
You just threw all sorts of electonic vocabulary at me. I'm pretty tech savvy, but with a mech engineering degree, i'm better equipped at solving a different set of problems, and with a law degree in the works, i can only create more problems.
Please draw stick diagrams or attach pictures with such devices I could splice in that prevent me from having to use those big sons of pregnant doges.
battlecry
« Reply #27 on: December 08, 2009, 02:40:37 PM »
Ato, I am also not an electrical engineer, but electronics is just plumbing.
If you just need to cut the voltage in half, two resistors will do it, see:
http://en.wikipedia.org/wiki/Voltage_divider
(But the load voltage to the Rizos will be proportional to the source voltage)
A zener diode clamps the voltage to a rated value, 5.6V or 6.2V.  See:
http://en.wikipedia.org/wiki/Zener_diode
This approach will give you a stable voltage at the zener value (unless the source drops below that), and you may be able to substitute the R in the shunt regulator for the Rizo resistor.  Make sure you get components rated for the correct wattage.
If the Rizzo draws less than 1A, you can wire one of these:
http://www.fairchildsemi.com/pf/LM/LM7806.html
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #28 on: December 09, 2009, 02:56:34 PM »
Yup, Rizoma gets no LED bucks from me until they make this voltage reduction box thingo go away.
« Last Edit: January 01, 2010, 03:37:20 AM by ungeheuer » Logged
golgofett
« Reply #29 on: December 26, 2009, 06:50:10 PM »
Just got 4 Avio 21's for Xmas.  There is no longer a black box.  The "black box" is now about the size of the new resistor pictured but flatter.  Almost like a pressure switch to run a weaponlight if that makes any sense.  Maybe the thickness of 3 quarters and the width of a dime?
2009 M1100 Gloss Black
Motovation Frame Sliders
Touring Seat
CRG Lanesplitters w/Rhinomoto Barends
Rizoma fender eliminator
Rizoma Avio 21's
Pages: 1 [2] 3   Go Up
