February 05, 2025, 11:09:44 AM
2009 M696 Parts
Topic: 2009 M696 Parts (Read 9055 times)
loves ze desmodromics.
Re: 2009 M696 Parts
Reply #15 on:
December 17, 2009, 08:37:47 AM »
Quote from: DoWorkSon on December 17, 2009, 08:35:20 AM
The steering damper smooths out steering and makes the bike feel more solid. The bike does not feel as loose or wobbly on the freeway or in the twisties.
Hmmm. This sounds like the damper is doing a bit more work than it should. The damper should be towards the lighter side of things, adjustment wise, and other problems may be stemming from other suspension issues, like over or under sprung rear shock, and forks.
Miami
Re: 2009 M696 Parts
Reply #16 on:
December 17, 2009, 09:23:22 AM »
is there any advantage to the dry clutch vs. the wet?
Re: 2009 M696 Parts
Reply #17 on:
December 17, 2009, 09:34:25 AM »
woah that's a whole other thread.
Miami
Re: 2009 M696 Parts
Reply #18 on:
December 17, 2009, 09:37:48 AM »
hey i do what i can.
do you think if i have the option of adding the price of pipes onto my financed total i should? The dealership i'm buying from carries both Quat-D and Two Brothers.
Re: 2009 M696 Parts
Reply #19 on:
December 17, 2009, 08:02:35 PM »
sometimes shops will do that if they have those parts in stock.
quat-d, juice box and k&n filter should be what you need for that setup.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Re: 2009 M696 Parts
Reply #20 on:
December 17, 2009, 09:12:34 PM »
Quote from: stopintime on December 17, 2009, 07:07:03 AM
....I suspect most
vented clutch
covers are there to "vent" the Ducati trademark rattle clutch and it's cool looks.
I have decided not to want it
I love your thought process there
. If I may borrow your wisdom for a moment - and hijack the thread for a second - then... I have decided not to want a black frame. I have also decided not to want a Moto Guzzi Griso (as well as, not instead of..)... I have further decided not to want ABS. I have decided not to want a Zard full-system *caveat: until such time as somebody makes a something to replace the DP ECU, then I reserve the right to re-want the Zard setup
. In the mean time I'm trying to decide to not want the DP full system but I fear that I'm beginning to actually like (I know... its an illness) how that thing looks. There I said it.
Sorry
Miami
, here's your thread back....
Last Edit: December 17, 2009, 09:15:04 PM by ungeheuer
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Re: 2009 M696 Parts
Reply #21 on:
December 17, 2009, 09:48:10 PM »
Quote from: ungeheuer on December 17, 2009, 09:12:34 PM
Sorry
Miami
just pick up a DP ecu like i did and get it over with. 10.5k rpm limit and no fueling issues. now just got to put the bike back together.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Re: 2009 M696 Parts
Reply #22 on:
December 18, 2009, 02:22:54 AM »
Quote from: Raux on December 17, 2009, 09:48:10 PM
Raux... I already have a DP ECU... it came with my Termi slip-ons.... but as it still expects to hear inputs from the lambda sensors.. and still tweats the dumb-arse flapper valve servo its no use with any other full system which dispenses with both of the aforementioned. I'd need the
other
DP ECU as supplied with the DP full system...and I cant see anybody having a spare one of those...
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
DoWorkSon
Re: 2009 M696 Parts
Reply #23 on:
December 18, 2009, 07:19:12 AM »
Quote from: ato memphis on December 17, 2009, 08:37:47 AM
Sorry, maybe I was a little dramatic in how i described what the steering damper did.
Where did you get the DP ECU by itself?
2009 M696--SOLD
Re: 2009 M696 Parts
Reply #24 on:
December 18, 2009, 08:02:59 AM »
Quote from: ungeheuer on December 18, 2009, 02:22:54 AM
other
you could go with the Duc.EE from Motocreations to get rid of the flapper valve and still just use the lambda with the DP ECU you have now. I'm working on a system for the 696/1100 with a local shop. 2 into 2 (with or without a crossover is unknown at this time-dyno testing will determine if a true 2 into 2) keeping the header pipes and lambda sensors, but getting rid of the flapper valve. Should come with a unique tail chop as well.
Re: 2009 M696 Parts
Reply #25 on:
December 18, 2009, 08:03:51 AM »
you'll get the most power out of a system with a cross-over.
Re: 2009 M696 Parts
Reply #26 on:
December 18, 2009, 08:04:36 AM »
Quote from: DoWorkSon on December 18, 2009, 07:19:12 AM
Ebay is your friend. a shop was going out of business. not sure how they had it on the shelf alone or if they had broke up the set to make more.. paid half the cost of the SS full system.
Re: 2009 M696 Parts
Reply #27 on:
December 18, 2009, 08:10:22 AM »
Quote from: ato memphis on December 18, 2009, 08:03:51 AM
i have a couple of 696 systems and an 1100 system for testing and development so I'll try several configurations. Not going to try and reinvent the wheel though. Motocreations has the Duc.EE so i'll recommend that to go with the system when they go for sale.
It's interesting that I just read today and now was confirmed from Unge that the new DP ECU keeps the lambda inputs. for race only systems, i'm surprised.
Re: 2009 M696 Parts
Reply #28 on:
December 18, 2009, 08:23:38 AM »
iirc, lambda is for emissions regulations, correct?
if so, silly to keep it for race ecus. then again, lots of race bikes still run carburettors because of the relative lack of gadgets needed.
Re: 2009 M696 Parts
Reply #29 on:
December 18, 2009, 08:47:14 AM »
yeah kinda wierd.
the new Siemens comes in three version then?
Stock (696/1100)
DP slipon (keeping lambda) (696/1100)
DP full (no lambda) (1100)
