February 06, 2025, 11:59:39 AM *
Pages: 1 [2]   Go Down
Author Topic: PCIII?  (Read 4098 times)
ArcDeDucati
« Reply #15 on: January 06, 2010, 09:33:21 AM »
You will def have to hunt for the old version if you want one. It is actually for the M1000ie if that helps. I would have to find my paperwork for the PN...
I don't want to make you go diggin through paperwork, but it would be a big help.  If it's for the M1000ie than I should still be able to get it through them no?
http://www.powercommander.com/powercommander/powercommander_iii_usb.aspx?mk=5&mdl=26&yr=2004
It's only available in one version, not sure if its the Race ready or the other.
Thanks for all the help everyone.
2007 Ducati S2R 800 - Totaled
2006 Triumph Thruxton - Sold
2007 Ducati S4R Testastretta
hypurone
« Reply #16 on: January 07, 2010, 04:09:03 AM »
ArcDeDucati, that looks like the part number I remember. But I will look for the PN when I get home tonight anyway...
There is some special hookup required on it as the connectors aren't right or the wiring needs some tweaking or something. I can't remember. Also the ground is really short and it limits where you can install it (you don't want to extend the ground wire as it will cause signal issues/breakup). Mine is tucked halfway under the tank on the left side so I can get to the faceplate buttons for on-the-fly tweaking.
You can see it peeking out here:
hypurone
« Reply #17 on: January 07, 2010, 02:56:14 PM »
ArcDeDucati, that is def the part number that was installed on my bike. I found the receipt!  waytogo
ArcDeDucati
« Reply #18 on: January 08, 2010, 10:40:58 AM »
Great. So this will allow for full adjustablity throughout the rpm's and throttle % WITHOUT the DP ECU?
hypurone
« Reply #19 on: January 11, 2010, 08:10:30 AM »
Yup, it is "pre EPA fine" vintage.
Pages: 1 [2]   Go Up
