Guess you gotta see it then.
My space saver Anderson is not so easy to use.
My first one for DSS worked a treat, this one is not so easy.
If your talking normal stand with two wheels then it doesn't compare.
From the way you are describing it, it should be a piece of cake to use.
Im currently using a bike lifter (the forklift type) which in its standard form is useless for a Ducati, but I've extended the arms it so I can stand the bike upright & slide a rod between the lifters arms & into the rear axle. Its easy to use, but unfortunately ties up my bike lifter, so I'm keen to get one of these as soon as they are ready!
