April 27, 2024, 12:22:44 PM *
Pages: 1 [2]   Go Down
Author Topic: Best Memo Line Writing in a Check to a Friend Ever  (Read 24244 times)
« Reply #15 on: January 14, 2010, 05:17:37 AM »
That awesome check to Verizon reminded me of the "Verizon doesn't know how to count" thing from a few years ago:
Call to verizon's billing dept:
G: Do you recognize that there's a difference between "point zero zero two dollars" and "point zero zero two cents"?
[pause]
M: Point zero zero two dollars?
G: Do you recognize that there is actually...
M: ...and point zero zero two cents.
G: Yes, do you you recognize there's a difference between those 2 numbers?
[pause]
M: No.
http://consumerist.com/2006/12/transcript-verizon-doesnt-know-how-to-count.html
I had to scroll down to the bottom after reading that one for ten minutes, and seeing how there was a long way to go.
cyrus buelton
aka JuddDDDdd
« Reply #16 on: January 14, 2010, 06:36:13 AM »
You should have included the dollar amount.  It really impacts the memo line.  Like if it was $5 then you're a cheap whore, but if it's $500 then you're pretty good at what ya do.  laughingdp
Um, what probably made it funny was the dollar amount.
I won't post how much it was........but.....it was >3k
I am very very good if I was getting that pay for a BJ.
1999 M750 (joint ownership)
2004 S4r (mineeee)
slowpoke13
« Reply #17 on: January 14, 2010, 08:06:14 AM »
so, you saying if I got $3K....
slowpokesan
cyrus buelton
aka JuddDDDdd
« Reply #18 on: January 14, 2010, 08:14:44 AM »
hahahahahhhahahaha
2004 S4r (mineeee)
Johnny OrganDonor
« Reply #19 on: January 14, 2010, 09:46:10 AM »
If you get $536.49 for that check, take the cash and run.  It was only written out for $0.002
The second term wasn't e^(2*pie[sic]) it was e^(i*pi)  which is equal to -1 from Euler's identity (one of the coolest equations ever):
e^(i*pi) + 1 =0, so e^(i*pi) = -1
The infinite series in the third term works out to 1 as expressed
So the check is for $(0.002 -1+1) = $0.002.
For $50 you can touch my
« Reply #20 on: January 14, 2010, 10:00:47 AM »
That's not my math-just the only version of the check I could find  Wink
Johnny OrganDonor
« Reply #21 on: January 14, 2010, 10:03:42 AM »
I knew that.   waytogo
Pages: 1 [2]   Go Up
