February 12, 2025, 01:56:36 PM *
Pages: 1 [2]   Go Down
Author Topic: Woodcraft rearsets  (Read 6914 times)
loves ze desmodromics.
« Reply #15 on: January 20, 2010, 10:07:05 AM »
That's not really the same, The lack of spring or o-ring rubber band didn't lock up the pedal, pushing it a perceived distance greater than normal did. Similar problems with the rear brake locking up can occur if there's not sufficient free-play above normal resting position if the brake fluid boils and expands - it has to go somewhere and if the pedal can't move, then the pistons will, clamping down on rear disc.
mikeb
« Reply #16 on: January 20, 2010, 10:25:37 AM »
Exactly....a sticky pedal reduces the free-play.
I see them as related because if the brake was dragging it was generating heat....boiling the fluid...makes the brakes lock a lot easier.  Combined with the reduced lever travel it caused a problem in my case.  They locked a lot easier than they should have.
Long and short of it is the fluid didn't have enough pressure to return the pedal in my case.  Result was a dragging brake that locked.
Not arguing your points.  Is it redundant?  Yes.  Unecessary?  If everything is functioning properly it is.  But that doesn't mean it doesn't serve a purpose.  Or it doesn't work.
In short millions of bikes have a return spring.  It doesn't hurt anything.
« Last Edit: January 20, 2010, 10:27:40 AM by mikeb » Logged
mikeb
« Reply #17 on: January 20, 2010, 10:34:01 AM »
I know someone that installed the wrong lever on his front master.  Bought a 2nd hand race SV that had a Honda (older F4I I believe) master on it.  He put a spare SV lever on it after a lowside and hadn't thought anything of it.  Next session as he was tipping in for a turn he felt the bike start to slow.  As he hit full lean the front end tucked.  He figured there was no free-play and the resultant heat cause them to lock.
Pages: 1 [2]   Go Up
