DucNaked
That's an odd mix of parts.
Any more pics?
Kopfjäger
Quote from: Speeddog on December 27, 2012, 06:36:46 PM
Any more pics?
There are several way back in this thread.  ;)
brad black
Quote from: Moto Motivo on December 26, 2012, 07:10:38 AM
moto you bastard i just found your website.  now i'm screwed.
i have been thinking all afternoon "i don't think i'd want a full fairing one" and so i found this http://www.motomotivo.com/1a.jpg
although now i'm swaying back towards full again.  no idea why
and the questions begin.
does that front fairing (and the full fairing) go straight onto the std ss headlight subframe?
does the endurance seat go straight onto the std ss rear frame?  i can see there's one little mount for the original side covers under the top rail that you've removed, but i'm kind of keen to keep mine as returnable to std as possible.  so i'd have to hide that.
and the inevitable (sigh) how much?
Brad The Bike Boy
http://www.bikeboy.org
Moto Motivo
Brad, thanks for the reply.  Please contact me trough my site and I'll gladly answer all your questions, that way we can keep this thread uncluttered.
Perfect Functional Two Wheel Art
      www.motomotivo.com
1.21GW
Moto Motivo: I just found your site as well.  Nice work!  Really remarkable seeing the transformations page.  An aside: did you consider putting a link to your page in your forum signature?  I had to search to find the website.  In any case, keep up the good work! [beer]
Hot links in sig lines are reserved for paying sponsors.
Quote8.  Members shall not promote their business or other forums in fashion that can be considered SPAM. Postings of such material may be removed by the moderators and an explanation will generally be provided, but not required. Repeat offenses may lead to suspension and/or removal. Advertisers are exempt and may post specials and/or information about their business.  Hotlinks to other websites are not allowed in sig lines. That is reserved for sponsors. More detailed vendor Rules are here:  [insert link]
The globe under his user name will have to suffice for now.
Quote from: brad black on December 22, 2012, 12:53:39 AM
there's a guy in Adelaide who has a 100hp, 800cc 696.  94mm bore.  from him:
"thought you might be interested  in the performance of the new 800cc two valve - 696 motor ( Red bike). The white 696, own the state champ and set new bears lap record at Mac Park, unfortunately they cancel the Phillip Island round which we were going to take the 800 , we thought a 1m 48s would have be about the mark.
specification of the 800cc
bore 94mm
stroke 57.2mm
45mm inlet valves
39.5 mm ex
both titanium of our own spec
our new inlet manifold heads
new ecu
stock cams and timing
14:1 compression
lightened crank and Carrillo rods
55mm butterfly's"
"Head rework is fairly substantial on the 800cc with new inlet track at a steeper angle, oval 55mm throttle bodies (999r) and our titanium valves.
The whole lot would cost about $3500 per pair. We also make carbon airboxes to suit.
There is more development to go on the 696 motor which is doing a reliable 86 hp. and has more conventional head .
The standard 696 stud configuration is larger at 74mm x 94mm and the cases are alot stronger in this area than early models.
So we needed to find 6mm in diameter.   3mm radius, 1.5mm off  the internal of the cases and the same off the OD of the barrels which we also shortened to match the 696 stroke of 57.2mm.
Pistons are CP to our spec as the pin is lower than a 1000 ds, weight is the same as a stock 88mm and we also set them for 48mm inlet which we have  run on this motor as part of the development program. Currently running 45mm as that's all that was required with the improved port flow.
The rev limiter is a bit shy at 10250 rpm  we'll run 11200 rpm on the track, this is still well within piston speed and acceleration limits.
We have also developed a cam manufacturing process and have lift profiles in mind but the maths is killing me!!!!
Cams can be alot more like 4V motors as the heads breath so well , we don't need as much duration and could even have shorter lobe separation.
This is why I've stuck with the stock 696 cam, although with the new inlets additional lift would help. From flow testing of the standards and ported stock inlet it's obvious that lift is no real advantage as they flow so poorly over 9mm (see attached)."
i was going to put it on my blog with some dyno charts and photos, just haven't got to it.
Very impressive.
Sounds like head reconfigure work akin to MBP or BCM, but local (to me).
1.21GW
Quote from: ducpainter on December 28, 2012, 03:34:32 PM
Oops.  Sorry. :-[
DucHead
Quote from: brad black on December 27, 2012, 02:22:47 PM
...i thought the 1990 900ss with the big white stripe was just the best looking thing ever...
Kopfjäger
supertjeduc
rozer
Is it just me or does anyone else also find it annoying when a non-offroad bike is photographed on such a location?
Kopfjäger
Quote from: rozer on December 30, 2012, 10:22:33 AM
It's just you.  ;) :D
