Cylinder Boring/Coating
Started by pearljazz, January 22, 2010, 01:33:17 AM
Quote from: howie on January 23, 2010, 01:20:55 AM
Blast from the past.  How many of you remember the aluminum block Chevy Vega?
<raises hand>
IIRC, they did OK as long as you didn't overheat 'em?
64duc
 In 1962 Oldsmobile built an aluminum block v8. I was 215 cu/in 215 hp. Bad azz little engine in the 2400 lb Cutlass. It too was a great performer until you overheated it. Exactly what happened to mine.
94 M900, 64 Diana 250
scott_araujo
Were these aluminum car engines prone to overheating because of insufficient cooling?  Or just so much fun to flog it just sorta happened a lot ? :)
Scott
Mr Earl
Quote from: 64duc on January 23, 2010, 06:32:04 AM
That 215 cid V8 engine was sold to British Leyland, and used by them in Land Rover vehicles, perhaps even to date (haven't followed it.)  I never knew what the cylinder technology was, though.
GM lopped off 2 cylinders, turned it into the odd-fire Buick V6 cast iron motor that went into the 1960s Buick Special, then sold it later to Jeep, and it went into CJs as the "Dauntless" V6.  Buick bought it back...  oops, precipitously off-topic, sorry.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Langanobob
Quote from: scott_araujo on January 23, 2010, 11:44:08 AM
Scott
Scott, I recall a questionable source telling me that the overheating issues had something to do with heat flow from the combustion chamber through aluminum being faster than through cast iron.  Not sure if that makes sense though if the cooling system was adequate to begin with.
Bob
Porsche Monkey
Nikasil was developed by Mahle and used in Porsche's in the late 60's.
d6a9p6
650 Pantah engines had it in 1985, I think all Pantahs starting in 1979 had it. Nikasil that is.  Don
Quote from: Langanobob on January 24, 2010, 06:16:23 AM
Bob
The biggest cause of overheating on those engines was the lack of phosphate free coolant in the US and knowledge that phosphate free coolant was needed for aluminum.
Quote from: howie on January 25, 2010, 02:56:16 AM
Was/is it a heat transfer issue or a corrosion issue on the aluminum?
The aluminum would slowly corrode in hotter areas, like the cylinder heads, combine with the phosphate to form aluminum phosphate and the aluminum phosphate would deposit itself in cooler regions like the cylinder block and radiator.  Silica in conventional coolant played a role in cooling system this too, though I don't remember what the problem was.
Quote from: d6a9p6 on January 24, 2010, 02:40:07 PM
1980.  yes.
my bud in hs had one, we loved it.  we dropped the engine and put in a 327 small block..  i forgot how he got the money, but he picked up an Edelbrock dual carb intake setup and holley 600 carbs.  it sounded like a friggin elephant.
i think it broke the differential... rofl
look at this one
Cosworth Vega on ebay
scott_araujo
So with nikasil....
Do you need to overbore a few thousands before plating to get the right tolerance?
Do you need to hone the nikasil after you plate?  Or the cylinder before you plate it?
Any issue on seating rings, etc.?  Are the rings made of special material to seat and play nicely with nikasil?
Scott
Quote from: scott_araujo on January 25, 2010, 09:09:58 AM
So with nikasil....
Scott
you have it mostly right.  they just remove the old coating and then check the surface (if any damage) the new coating will be over and they will use your pistons to hone it down.
you don't need to hone it, you will just get it angry.
these guys are the ones i used.  they have a very good rep
http://kustom-kraft.com/NEWNIKASIL.html
scott_araujo
