Moto Air-Conditioner
Started by arai_speed, January 22, 2010, 12:55:14 PM
dennisd
#32
Quoteare you in direct contact with the water?
I wear the vest over the Under Armor Heat Gear T-shirt; so, yes and no.  The vest isn't directly against my skin (although some are designed to be worn against your skin, the one I have isn't) but eventually the T-shirt will get damp.
QuoteYes. You will get wet. Buddy of mine had one, worked great. Not something he could wear with work clothes though...
QuoteI never put mine on because I didn't want to get wet (actually, damp). Turns out I was wet at the end of every session anyway
That's the reason I use the Under Armor T-shirt.  Even though it gets damp, it never feels yucky like a cotton T-shirt will when damp.  The other advantage of the Under Armor Heat Gear shirt is that it doesn't look wet.  I've gone into restaurants and such and no one knew anything was out of the ordinary.
Quotethis brings up a good point. once you start sweating it does the same thing as this vest IF you have the right kind of clothing on. I bought some BMW full body stuff that in 100 deg heat feels cold while riding with leathers.
You are right; the cooling vest just takes it to the next level.  For one thing, you don't have to get hot & sweaty before it starts to work; it prevents you from getting hot.  They also have a long sleeve version of the vest but they don't recommend using it unless the temps are above 90F because it might reduce your core temp too much (so they say anyway).
I carry a zip-lock bag with me on long days.  If the vest gets too dry to work, I simply beg some water somewhere, put the vest  and some water in the bag and within a couple of minutes it's ready to go again.  I find it to work for about 5 to 6 hours before I recharge.
Oh heavens! Now older riders or peolpe who are likely to suffer from heat stroke can stay cool enough to continue to ride! Heavens!
And Duck-Stew-how come this isn't okay but your heated vest is?
could someone please sticky this thread?
NorDog
Quote from: ducatiz on January 26, 2010, 09:49:02 AM
I thought the whole idea of an air conditioner was to avoid getty sticky.   ;)
superjohn
If I could get one that connected into the back of a helmet like a hazmat suit I use it with a yellow Aerostich suit and try and make people nervous.
dennisd
QuoteOh heavens! Now older riders or peolpe who are likely to suffer from heat stroke can stay cool enough to continue to ride! Heavens!
HEY; I resemble that remark!!!  :'(
But I'd still never use a moto air conditioner. [laugh]
Quote from: superjohn on January 26, 2010, 02:21:55 PM
[laugh] [clap]
muskrat
you'd be on the terrorist list if you did that but it would be funnier than hell.  ;D
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
matmcd78
Does it have an airfilter or just pull air from the back of the bike where the exhaust ends? And then blows the exhaust air up the jacket and into the confines of your helmet? I didn't see a warning label.
I looks like it pulls from the front and exhausts the hot air from the heat exchanger out the back...
superjohn
Quote from: matmcd78 on January 27, 2010, 01:16:43 AM
If it did that, it'd save those Harley guys a lot of money. By the time they got to the bar or Starbucks or whatever, they'd already be loopy.
